Engine management light came on last weekend but went off the next day.
Did a scan yesterday and found some new codes. I've removed the standard codes of fault handles, buttons and footwell heaters. Quote:
I've used tow bar and electrics with no issues. It all worked fine. I checked the wiring and it looked fine. Quote:
Is it normally new glow plug? I think the intake manifold runner control is was cause my engine managment light to come on. I've not seen it before. Anyone got any ideas? Its not come back since. Quote:
I got no idea what it is talking about. Quote:
I assume they came on cause of the piston ring aging? Quote:
Battery has been fine. No issues.
The two air compressor ones should both be fixed by the kit Andy supplies.
Would not worry about the battery one, it just means the battery level dropped and the car shut something off to save power. I get these all the time at varying stages but the car is always fine.
I rebuild the suspension pump over the week and went for a drive.
I'll scan it again tonight and see if anything has popped back up.
The g291 fault is because of low pressure and the over temp because its been running too long and overheating because its not able to get up to pressure but since you already rebuilt it then that might be ok now.
The battery regulator has dropped into first stage possibly when you have been messing about in the car with electrics on and no engine running, stage one is nothing to worry about if you scan and see it go through all the stages 1-5 in quick succession then that would most likely show a knackered battery. The mech failure, don't know, possibly a flap motor???
Del ![]() |
Whilst I was in my car today scanning the engine and HVAC ECU due to other issues, thought I'd check the level control module. Result, no faults showing since the Andy kit was installed in January.
All the above fault codes are now gone and not returned.
WooHoo. Apart from the normal ones.
