Hi all
just getting to grips with the new D3 . I have found with mine that once i have set the total close and open for the windows with the door switch and also checked that it is on in the MMI. Once the car has been locked and gone to sleep. it does not remember the settings and i cannot use the remount to open and close the windows. Would anyone have any tips. Have set it up just as in the book and works fine until the car is lock and gone to sleep. Any tips would be a great help Thanks very much Steve ![]() |
Do you mean the one-touch closing and opening where you open all the way and then press the button again and then do the same with closing?
Sorry was thinking about the opening and closing with the use
of the remont key fob. |
I just press and hold the unlock or lock on the fob and it does it. Same as most Audis I've driven
Yep mine seems to forget the setting once the car is locked.
I remember my D2 would work fine as you Said it was just a case of holding down the buttons on the remont |
Does you one-touch work?
ie if you press the electric window button on the door to open the window, does it open-close all the way with just a quick press? This needs to be working as a prerequisite for total closure / comfork opening to work. |
