Old 26th September 2014, 05:12 PM
Default Immobilizer vs. Instrument Cluster swap
OK guys, here is the question.
Is the instrument cluster a straight swap.
Reason: I am changing my small lcd dis to a wide dis one.
What is my main concern?? Conversation I've had today with my good mate who could not start up his older A6 years ago after swapping clocks.
Quick story. Few years ago, on his A6, the old shape one, but not the very first one, he decided to change/upgrade his clocks.
After swap car would not start at all, it was cranking but thats it.
So the reason for that was that either a immobilizer chip was within the instrument cluster, or somehow wired/paired with the original cluster.
Sooo, is it possible that I will experience exactly same problem??
Will I have to re-code the immobilizer or it is actually just a straight swap and mileage correction??
Or mileage isn't even stored in the cluster??
THANK YOU !!!
Old 26th September 2014, 05:28 PM
IIRC in previous models you needed the login code for the donor part's car and yours. It also needed to be the correct immobiliser version denoted by the letter on the end of the part number. I hope ours are simpler as I would also like this.
Old 26th September 2014, 07:14 PM
You will quite possibly get component protection on the car when the Dash is swapped but I don't think you'll get immobiliser issues. It should just need a trip to the local Audi Stealer to get the component protection removed after swapping which is normally about £30-35
Old 26th September 2014, 07:31 PM
gninnam gninnam is offline
I found that none of the Audi Stealers round my neck of the woods would entertain doing the component protection code
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 26th September 2014, 09:14 PM
mannyo mannyo is offline
On the D3 the immobiliser is not part of the cluster, you can swap the cluster straight over and the car will still run.
BUT
Nothing will work correctly until the car has made a trip to an Audi dealer to have component protection removed.
Manny
Past
Old 26th September 2014, 09:56 PM
As above, it will run, but clocks wont work until you have trip to Audi to sort CP.
Note, I dont know how easy mileage correction is. D2 PF was ok, but D2 FL was only do-able with a soldering iron on a bench job.
Never looked into the D3, but I wouldn't assume straight forward unless you've come across examples of it being done, and I've not seen any....
