Old 6th October 2014, 09:22 PM
gninnam gninnam is offline
Default Replacing the Suspension Controller unit
Folks - have replaced the compressor for the air suspension (brand new unit) and the bloody light still comes on after some time
Was told it's probably the control unit so have got one from A8 Parts.
So - has anyone replaced one of these and if so, how did you do it (I believe it's under the carpet on the passenger side - just below the glove box).
Plus once replaced, does it need coding?
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 7th October 2014, 06:37 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
I got no idea where it is or how to replace it but have you scanned the system to check for codes?
If the unit needs replacing I thought it would be obvious with codes supporting it?
[center]
06 3.0TDI Quattro:
Options:
Old 7th October 2014, 08:30 AM
An Audi engineer replaced the compressor and when told the car still had the same issue he diagnosed it as the controller so for a small outlay I thought I'd get a replacement.
If no one can help then I will pass it back to him to fit.
Cheers anyway.
Andy.
Current cars:
BMW i4 M-Sport
Old 7th October 2014, 08:40 AM
ScottD3's Avatar
Try this.
http://www.volkspage.net/technik/ssp/ssp/SSP_292.pdf
Page 10.
[center]
06 3.0TDI Quattro:
Options:
Old 7th October 2014, 10:34 AM
Cheers - already have that. Doesn't tell you how to remove it.
I removed the carpet and can see it, but it's tucked behind a lot of parts and looks difficult to get out.
Just wondering if there is any advice on who/what to do
Andy.
Current cars:
BMW i4 M-Sport
Old 7th October 2014, 01:36 PM
mannyo mannyo is offline
Are you sure its not simply the suspension relay which is a common failing part, unlike the controller. A failed relay can cause the compressor to run on and eventually burn out, even though the controller has attempted to shut it down. Would give the symptoms of a failed controller because the suspension is not doing what the controller asks.
If you ever replace the compressor, replace the relay at the same time otherwise the replacement compressor could die as well. With the D3 VCDS seems to be an ownership requirement, as it saves so much time and trial and error.
Manny
Past
