Anyone tried the new Titanium range?
I just noticed these today when I was looking for good deals on Edge 5w30 for my next oil change. I have been reading a bit on various sites such as bobistheoilguy and it sounds like a good new oil. I may give it a go for my next oil change. Not sure whether to go for 0w30 or 0W40, they seem very similar, 72 vs 79 40C viscosity, 12.3 vs 13.1 at 100C. Not sure what the High Temp 105C viscosity is, some forum post said its around 3.6 http://castroledge.com/uk/products/oil-range http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/D9F10BA4592D660380257C9F003038FA/$File/BPXE-9HCV4Z.pdf http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/EA379E05EC9FB93980257C9100583EA6/$File/BPXE-9GY8VJ.pdf Last edited by Goran; 17th October 2014 at 03:50 PM. |
We should be on 5w40 Goran - 0w anything is too thin and will find its way out of the engine more readily.
If you're looking for better protection for the engine then the Fuchs Pro Race S is still well regarded, but doesn't have Audi spec approval. Mine had Quantum Platinum in at (Edge basically in a VAG bottle) last service, but only because they failed to spot the Fuchs in the boot! The Fuchs does seem to give quieter start up from cold, but it may be my subjective imagination ![]()
from what I read that is wrong. The 0 number means it is less viscous at a lower temperature, the number after the W means it is more viscous at operating temp. 0 anything is always better. I posted the operating temp viscosities above the difference is less than 1.
I also read this today, check out post no.5 http://www.audizine.com/forum/showth...-Oil-Why-5W-40 Also Opie oils reccomends it under the VW 502 standard. In fact Edge 5W30 is less viscous at operating temp! 12.0mm2/s . http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/855EDA91E5358A7A80257BF200518884/$File/BPXE-9BZRHU.pdf Just wondering if anyone is using any of the ones with added Titanium. Last edited by Goran; 17th October 2014 at 07:15 PM. |
First digit is viscosity at low temperatures, the lower number means lesser viscosity so it gets lifted and provides oil pressure sooner. This is important at cold climates, you don't really need first digit to be 0 unless you are using car at temperatures lower then -30C. At UK temps(except Scotland maybe) even 15 for the first digit will be fine.
Quantum Longlife III 5W30 (or Castrol Edge equivalent) does good job for everyday driving and can be sourced relatively cheap. It is suitable for PD diesel engines which experience high pressures at camshafts operating PD units, they have plenty of high pressure and anti-seize additives so even at cold starts with no oil pressure there is no metal to metal contact so it does not matter if oil pressure is reached in 1 or 1.5 seconds If you want better protection when pushed hard like on track you should be paying more attention to second number after W. You want it to be as high as possible to retain viscosity at high temps, 10W60 or 10W50 would be good choice in that case.
I don't track the car I just want lower wear from cold start. Even at 40C you can see the viscosity of even these synthetic oils is 7 times higher than at operating temp.
I just need something to worry about ![]() Also, I have been logging data and the webasto coolant heater barely raises oil temp by 1 degree when ambient temp is 12C so it doesn't help much with the oil. |
It does not really matter what the viscosity is at low temp as long as pump can suck up oil quickly and provide sufficient pressure in short time, when it becomes like honey is when you should get worried. But even if it could not provide the pressure modern oils contain fair amount of high pressure and anti seize additives that it could probably run for couple several minutes without oil pressure at all lubricating from the remains of oil from previous use. Any damage would appear at hotspots due to lack of cooling that oil flow provides before flow or viscosity play any part.
In general higher viscosity is better in terms of protection unless it's too viscous to for pump to suck it up quickly. But it does have a drawback that more viscous oil need produces more resistance and takes more power and uses more fuel. As you do not track your car I believe Quantum Longlife III will provide very good protection and value for money, just don't leave it to longlife service intervals but replace it every 8-10k miles or at least once a year which ever comes first.
