Old 17th December 2014, 12:02 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default Wiper Refurbishment
The wipers on the D3 are ready for replacement and I thought I'd go the same route as my A4 and refurbishment with fitting new rubbers.
Save a bit of money and its a satisfying 30 minute job to do on your lunch break.
I got a set of spare wipers and was going to do the work on them.
Since I've not done these before I thought it would be a good just in case any thing broke.
It was over 2 years ago since I did my wipers, so I referred back to my orignal thread to remind me how to do it.
[center]
06 3.0TDI Quattro:
Options:
Old 17th December 2014, 12:03 PM
ScottD3's Avatar
First, Get your aero wipers and the wiper blade kit (Part No, 1K0 955 429)
Second, Pull the ends off.
Thirdly, With the ends off, you want to find this clip and bend it up so you can pull the rubber blade out.
Fourth, With the ends off take the old the blades out and give the unit a good clean.
Fifth, put the new blades in, crimp the clamp down again and put the ends on.
You don't have to do the next steps but I did cause I was obsessed with plasti dip.
six, put the wipers in your spray booth.
seven, Cover in plasti dip and enjoy
[center]
06 3.0TDI Quattro:
Options:
Old 17th December 2014, 12:08 PM
ScottD3's Avatar
That was all well and good.
It worked for a couple of different wipers that friends and family have done.
But not on the D3 wipers.
As you can see here.
Its two metal strips and the all the rubber in the middle is the blade and unit.
The fin is not separate from the blade like the others and its all clipped in really hard.
I'm not sure if you can get refurbishing kits for these but I will look, unless someone knows the answer?
I'm not sure if the D2 has aero wipers and if they do if this is possible.
But if you do, I do have a spare set of new blades if you want to attempt this.
[center]
06 3.0TDI Quattro:
Options:
Old 17th December 2014, 04:02 PM
D2 uses traditional metal wiper blades and not Aero ones.
Old 17th December 2014, 04:50 PM
Indeed, though I've fitted aero ones to my D2.
Old 17th December 2014, 06:32 PM
Johnmed's Avatar
Johnmed Johnmed is offline
That had me reading with interest, shame it didn't work out. I just forked out £52 for a set the other day at Audi, having searched all the local shops and online retailers to no avail for a set of new wipers.
2007 Mini Cooper S R56
