Hi people I've done a bit of searching on here for replacement from the standard bulb to led on the sidelight and the front fogs which led bulbs do I need, im not doing the drl option
cheers trev |
Side lights are W5W 12v.
Fog lights are H11 55W. Or H7 55W, best to check (thanks snapdragon) As for replacing these with LED's I can't give any recommendation, but I would think they would have to be Canbus error free. Quick search on google and ebay gives lots of choices. Sides: http://www.ebay.co.uk/itm/2-X-ERROR-...item58ae8d8d5b Fogs: http://www.ebay.co.uk/itm/2x-H11-CAN...item339a2d6f73
Matt 2004 A8 3.7q, 1998 A4 2.8q, 1994 Coupe 2.8q SORN, Last edited by mattylondon; 30th December 2014 at 09:57 AM. |
My fogs are H7, some are H11, so best to check first.
You will get bulb out errors though unless you get some sort of electrical shunt installed. |
cheers guys is there any that doesn't give any errors
cheers trev |
