Old 5th January 2015, 09:39 PM
Default Replacing G200 lateral acceleration sender
It looks like I have a fault with the above sensor/sender unit on my D3 4.2 lwb which is a bit of a beeatch because the whole centre console has to come out to change it. Does anyone have any idea wether it's a straightforward swap and it will just function or does it need setting up with either VAS at an Audi stealer or can it be set up / re commissioned using vagcom?
Thanks for any help anyone can give with this . . .
Old 5th January 2015, 10:19 PM
Workshop manual only states, If control module is replaced, select "Replace" function for respective control module in Guided Fault Finding using the Vehicle Diagnosis, Testing and Information System (VAS 505x). I can't give any light if VCDS can also set it up.
Hope the attached PDF helps a bit. Good luck
Matt
Old 6th January 2015, 11:24 AM
Found a useful thread about using VCDS after a Lateral Acceleration Sensor replacement in a TT.
http://www.audiworld.com/forums/tt-m...-g200-2746174/
Matt
Old 6th January 2015, 04:26 PM
Thanks Matt that's very helpful - much appreciated
Replacement sensor on its way from A8 Parts so just a load of dismantling, reassembling and vagcomming to do!
Old 15th January 2015, 06:39 AM
Update. So the sensor is in it now works fine . However all the lights are still on the dash but on vcds the code has gone. It seems to have re set itself.
The only fault now is dtc memory of abs controller and a valves voltage supply to abs pump
Dose any one have any idea ?
The abs module was changed about 5 weeks ago and the problem was cured but now this ?
We are clueless can any one help please ?
Old 15th January 2015, 08:49 AM
I assume you did recalibrate the newly installed G200 module? It needs to between -1.5 and +1.5 m/sē. And the installation was done with the battery disconnected?
Matt
