Old 28th January 2015, 04:26 PM
davyp davyp is offline
Default MMI Problem
Hi, been lurking on here a while, this is my first post. I've recently bought a 2004 4 litre TDI, all electrics and mmi had been working until the module that controls the electric window switches in the drivers door packed in. Replaced the module but now there's no power going to the mmi and centre console. Any suggestions as to what's wrong? I understand it's a bit of a broad question and all help is greatly appreciated. Thanks.
Old 28th January 2015, 04:45 PM
Check the fuses, they are in at least 4 places, driver and passenger end-caps of dash and left and right cover in the luggage compartment. Maybe more I don't know of.
https://dl.dropboxusercontent.com/u/...es-pred-d3.doc
Old 28th January 2015, 05:03 PM
is that part of the fibre ring, did you plug everything back in correctly
Old 28th January 2015, 05:11 PM
Thanks guys. There was one fuse replaced. Will check connections.
Old 28th January 2015, 09:24 PM
Don't think there's anything in the doors that would stop the MMI, but then again.. Certainly no MOST loop stuff.
Old 29th January 2015, 07:28 AM
when he said module that controls the windows, i thought he was refering to one of the main modules not a door based one. if its in the door its defo not on the most circuit
