Go Back   A8 Parts Forum > A8 D3 > D3 - Common Faults
D3 - Common Faults Quick links to all known common faults and their solutions
Old 11th March 2015, 04:49 PM
Default Drain cleaning again
So it's been a wee while since I last done the drains on the car and it's been dry here for a few days, so thought I would get busy.
Now the car does not live under trees but I was shocked at how much twigs and leaf debris that has accumulated since I last done it.
So today I decided to attack the scuttle with a different approach, the missus had a long thin brush kicking about under the stairs that's never used so I thought I would give it a go. It's very effective as the leaf debris and stuff sticks to it and gets pulled out quite easily so using that I went at it with the brush and Hoover for about 40 mins till it was clean.
The brush was most effective going in under the plenum from driver side, and the Hoover detailing attachment was best in the passenger side down through the heater hoses.
I also had a go again at the sunroof channels cleaned them out with wet wipes as there was a fine layer of sediment, I then got the bug spray bottle out and pumped warm soapy water down the forward drain hoses and then poured more water in the drainage tray and made sure the water drained away on its own.
After all the brushing and hoovering I got boiling water and flushed the scuttle out and made sure it came down form both sides of the tunnel.
Name:	File 11-03-2015 17 45 35.jpg
ID:	10324   Click image for larger version
Name:	2015-03-11 16.05.58.jpg
ID:	10325   Click image for larger version
Name:	2015-03-11 16.05.40.jpg
ID:	10326   Click image for larger version
Name:	2015-03-11 16.23.21.jpg
ID:	10327   Click image for larger version
Name:	2015-03-11 16.23.53.jpg
ID:	10328   Click image for larger version
Name:	2015-03-11 16.23.32.jpg
ID:	10329   Click image for larger version
Name:	2015-03-11 16.24.05.jpg
ID:	10330   Click image for larger version
Name:	2015-03-11 16.25.02.jpg
Old 11th March 2015, 10:58 PM
Get the dyson out lad, better still, get a 50 litre compressor and it will blast the lot out and esp nozzling it down sunroof and door drains for example. Very cheap plus get some air tools and u will never be afraid of heavy duty on jack stands again ! Shock don't pull init. ��
Old 12th March 2015, 07:36 AM
I would love a compressor, however I would not advise using it to clean sunroof drains, if the outlet is properly blocked you run the risk of ruptured drain tubes.
The brush and vax was quite effective just slow.
Old 12th March 2015, 01:08 PM
Conquistador's Avatar
Good post. For the sunroof I found this video quite helpful too...
https://www.youtube.com/watch?v=IFJXX0s6PfU
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 15th March 2015, 05:52 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
The sunroof is a pain.
My drains was blocked.
I removed the wheels, stripped the arch liner and cleaned the end of the drain tubes from the wheel side.
The ends are rubber and gets full of gunk.
Once that is out all that nasty gunky water runs down your arm.
I need to do my scuttle area as well.
That's loaded with crap.
[center]
06 3.0TDI Quattro:
Options:
Old 3rd April 2015, 01:45 PM
mannyo mannyo is offline
Found out the hard way that at least one of my rear sunroof drains are blocked. Left work yesterday and the rear seat got soaked when I went round a corner.
Same today after some rain overnight.
So just how difficult is it to gain access to the rear sunroof drains in the wheel arch.
Manny
Past
