hi guys
need help with this please , i have installed everything inow need to code everything in the only problem is the instructions are in german and they are using something other than vcds to code the car any ideas or help appreciated thanks nath |
post up the instructions you have and will convert it to vcds if possible
the car is recognising the camera and that the equipment is installed
its now coming up with a 03006 fault code which when googled is saying there is no calibratiion been done for guidelines the problem i have is i cannot even see the picture from the camera nevermind the back up lines (just a black screen) i need to check the camera has indeed got an output |
on the d3 calibration is also required, this was done with some expensive laser kit that not many dealers had, i presume there is a way around this by just telling it that its been calibrated. the german docs you have may refer to the vas system rather than vagcom, but you should be able to translate and find the correct module and location in vcds
You can ignore the calibration error, it does indeed need to be done with lasers and a big domino looking device. But I have done the same thing as you and mine works fine without the calibration.
As for a black screen that sounds like you have not got a signal, are you fitting the reverse cam module along with the oem camera etc or is it third party stuff?
Del ![]() |
i am trying to retrofit the manufacturers original kit to give an oem factory appearance and use
ive used the following equipment 4H0 907 441 .... this is the part number for the control module i cannot see a revision number on the box but will check again tommorow 4E0 827 574 H this is the part number for the grip handle and camera mount 8K0 980 551 B this is the part number for the rear camera itself all the parts where listed under the audi 4h d4 a8/s8 because you cannot buy an original audi loom i bought a kufatec loom http://www.kufatec.co.uk/shop/en/Aud...ess-Audi-A8-4H one thing of note is at the bottom of the description under notes it reccomends having revision x on the 4ho 997 441 i checked before hand with kufatec and they stated this was ok with my control module after installing everything as a factory installation would i then attempted to code by altering the following by converting kufatecs manual address 19 in vcds and altered the installation list to include the rear view camera address 5f in vcds and altered bit 7 (this gives the mmi an option for rear view camera ) address 6c in vcds which requires coding correctly so as car knows if trailer is being used and if long or short wheel base and if has parking sensors system (mine has parking sensors front and rear ) address 10 in vcds and made sure the rear camera option is selected for when reverse gear is engaged it states at the bottom to reset the mmi .... not managed this yet as it appears its not as simple as the d2 and d3 as there is no set up button ive tried to reset via vcds but it wont connect to the control module when i start car and engage reverse the screen has definately changed to incude the image this is the original https://www.google.co.uk/search?q=au...2F%3B800%3B480 this is what i have now but with no actual picture https://www.google.co.uk/search?q=au...w%3B1280%3B720 any help appreciated cheers guys been messing all day trying to find correct info but theres virtually no info on web regarding doing this |
