D3 - Common Faults Quick links to all known common faults and their solutions |
As per title, the soft close doesn't work anymore no matter how many times I lock / unlock the car and open / shut the boot. It just doesn't do the gentle pull down anymore.
I am having battery issues at the moment, (I get the Energy management Battery level warning) so don't know if this is related.
Matt 2004 A8 3.7q, 1998 A4 2.8q, 1994 Coupe 2.8q SORN, Last edited by mattylondon; 22nd March 2015 at 05:21 PM. |
There's a few things that won't work when battery manager starts cutting consumers.
I know from my experiences that the comfort access is one of them. If you battery is fully charged then just change the last digit on the serial number to fool the manager into thinking its a new battery. It should then at least start working again if it was just indeed an issue with the battery manager
Del ![]() |
Only my boot is soft close.
The issues happened Saturday morning, started the '8 up and MMI didn't work - no screen no music no warnings. About 2 mins later the MMI screen moved up and the radio came on, but there was an audible pop coming from the speakers then a click from a relay in the boot. The MMI screen started blanking and resetting once every two mins or so.... Just what I needed on a busy weekend! I did what I had to do then parked up, engine off, and got VCDS. Battery now was at 40% and the clicking was still going (probably the Bose DSP switching on / off and draining the battery) ![]() At this stage I couldn't access any of the modules on the MOST loop in VCDS and the MMI would not work in the car, either the Bose DSP is faulting or the energy management has turned it off. I was worried I'd get a flat battery so drove the car to parents driveway where I started to investigate the MOST modules, as I thought that was the issue. I removed the Bose DSP from the loop and all was ok, no relay clicking & MMI behaved normal now just without sound. Added it back into the MOST loop and no MMI problems, sound is normal no audible pop. Scratch my head a bit and deduce it's probably a battery issue, which is where I had to leave the problem for now. I'll get a charger on the battery tomorrow evening and take it from there. Hopefully will get the soft close boot back ![]()
Looking at your battery voltage on screenshot of VCDS it is empty. Empty battery voltage varies a bit depending on source of information and battery type, make but generally accepted empty voltage is 11.9V for flooded lead acid battery. As yours is showing 11.65V consider it fully discharged. You can probably still start car with that voltage but the battery is working on reserve capacity and it is deteriorating considerably at that low stage of charge. Fully charged battery should have resting voltage around 12.6V
Edit: By the way I think 40% is battery condition not charge level. So fully charged battery has 40% of original fully charged capacity/CCA left not that it is 40% charged at the moment. Normally I would say you need to replace battery when it gets to 50% health for summer use or 60% for winter use.
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 22nd March 2015 at 08:29 PM. |
Do you think it is an electronic problem or could it be a coincidence that the spring has snapped? There is a spring similar to one in a biro pen and the hook on one end snaps off with fret wear - meaning the mechanism above the bumper (not in the boot the lid) doesn't work anymore. It is a common problem. there is a thread with photos somewhere.
