Old 25th March 2015, 10:18 AM
barzya8 barzya8 is offline
Default Remote control batteries
Hi Guys & Girls,
Could someone please confirm how many batteries are in the D2 remote key fob. I have just changed my Central locking pump, which now only works on the key in the lock, but not the remote. Thought I would change the batteries. On investigation one set of keys has two batteries, the 2nd set only had one battery in it.
Would you also know what battery type/number I should replace with.
Is there a set process to go through to get the key remote to work again.
Thanks
David
Guildford, Surrey
Bose sound system.
Audi Navigation Plus.
20 inch Final Edition alloys
Old 25th March 2015, 08:18 PM
x2 3v coincell, dont know the code.
Old 25th March 2015, 09:03 PM
1620 is the battery code for mine - about 1cm diameter - just bought some Duracell ones off ebay for next to nothing incl delivery
Old 25th March 2015, 09:10 PM
I wish all batteries lasted 15 years !! Ive got Duracell rechargables for my petzl head-torch i use all the time, but they seriously loose their stamina after what doesn't seem like loads of charges.
Old 26th March 2015, 11:45 AM
Thanks Guys,
How do I reset the remote to read the new central locking pump should I need to after replacing batteries?.
Thanks
David
Guildford, Surrey
Bose sound system.
Old 26th March 2015, 12:01 PM
You need at least 2 keys:
1.Switch ignition on and leave the key in ignition
2.Lock vehicle from outside with the key to be adapted by
way of the driver's lock door.
3.Within 5 seconds press "unlock" key of remote key until
next memory position is reached (so it will be once for 1st key, twice for second key etc).
Each time the button is pressed the hazard lights will flash to
confirm.
4.Wait 5 seconds.
5.Now press the "unlock" key again to confirm the matching
process.
This vehicle key is now saved and the central locking must unlock.
You can then proceed to next key and save it in another memory position.
