Old 6th April 2015, 03:00 PM
tipptop tipptop is offline
Default 02596 code
Hi all, any help appreciated with clearing this code... I replaced the rear pads and discs, did it properly, battery charger, followed the procedure to the letter. I did the adaptation for the new pads @11mm, followed by function test. Code still won't clear. I repeated the adaptation and function test about 5 times but no dice. Everything is working properly, no lights on the cluster, just this bloody code won't clear. Am I missing something??
A8 D3 3.0tdi quattro 2006
A6 C5 1.9tdi 2004
A4 B5 1.9tdi quattro 1997
Old 6th April 2015, 03:12 PM
Have you cleared it from all relevant sections on vagcom? The code may be showing in more than one module perhaps?
Possibly clear all codes across the board then try leaving the handbrake off but locking the car and it will cycle a brake test automatically as you lock the car, see if that resets everything?
Old 6th April 2015, 04:09 PM
Hi thanks for reply, yeah its just showing in 53 park brake control but I've deleted maybe 20 times both directly in 53 and another 20 times through autoscan. It just pops back immediately.
I did read another post about that said to do the adaptation, function test, hold engine stop button, lock car, then try clear code again. Didn't work either. Should the park brake motors be heard to move after I finish the function test and lock the car with handbrake left off? Should it set itself or something? It definitely didn't do anything after I locked the car with it off...
A6 C5 1.9tdi 2004
Old 6th April 2015, 04:29 PM
Yes you should hear the motors wind in and back out again on both sides whilst they perform the test
Old 6th April 2015, 05:35 PM
possibly the park brake isnt working or what happened with mine there was no signal from the sensor so its presumed not working
Old 6th April 2015, 06:27 PM
When I did mine a couple of years ago, I remember something similar.
It required turning the ignition off and on between steps at some point in the process which was easily overlooked.
