Old 7th April 2015, 09:48 AM
Witchfinder's Avatar
Witchfinder Witchfinder is offline
Default Weird lights problem
Hello all. I've had my S8 a couple of weeks now. One of the first things I noticed about it was this curious little switch. It doesn't seem to do anything at all, and I've toggled it back and forth a few times over the past couple of weeks, hoping to notice a difference. The only difference I have noticed is that in the down position, I get a more bumpy ride feeling from the back end.
Then last night, driving home on the M60 in heavy fog, I tried to use the fog lights. The fronts worked fine, but the rears did not engage, and interestingly, the light on the dash did not come on. That got me to thinking that maybe the switch is related to an aftermarket towbar.
I looked under the back of the car this morning, and can't see any evidence of a towbar prep. Toggling the switch doesn't affect the fog lamps, so now I have no idea what is going on. It can't be bulbs, because I'd expect a bulb warning, and the dash light to still come on.
If anyone has any suggestions or thoughts, I'd really appreciate it. Thanks!
Old 7th April 2015, 09:50 AM
Not OEM for sure.
Old 7th April 2015, 10:42 AM
Not OEM for sure.
Yeah, it does stand out glaringly, but I have no idea what it does. Any thoughts on the fog lamp problem?
Old 7th April 2015, 02:53 PM
OK, quick update - I took it back to the Jag dealer in Leeds who didn't have a clue, and have booked me into the Stockport Audi dealer for them to sort it - fortunately under warranty.
Hopefully they'll install facelift light clusters. Well, I can dream, can't I?
I'll post back when I find out what the problem is.
Old 8th April 2015, 09:01 AM
I had a similar switch on mine that by-passed the TV in motion switch, so you could watch TV on the move.
Old 10th April 2015, 02:08 PM
Stockport Audi are a bit stumped. Apparently the car thinks there's a trailer attached, which is why it's not activating the fogs. They're still working on it.
UPDATE: As I understand it, the situation is this:
•The S8 I bought from as previously had an aftermarket towing kit fitted.
•The towing kit has subsequently been removed from my car prior to me viewing and purchasing it. I assume this was done by the former keeper before s/he traded it in.
•The towing kit was wired in such a way that it is connected electrically to the rear seat entertainment system.
•Removing the fuse connected to this system confirms our suspicions - when the fuse is out, the RSE doesn't work, but the foglights do work. While the fuse is connected, the RSE will work, but the foglights do not; the car behaves as if a trailer were connected and registers a number of fault codes.
•At present, the fuse is sitting in my cupholder. The kids will have to make do without the RSE until this gets resolved, as safety and roadworthiness is my primary concern.
The dealer group are going to talk to their "warranty clerk" on Monday. This had better be covered or the words "unroadworthy condition" and "Sale of Goods Act 1979" might be seeing some use.
Rob
2013 Audi A7 BiTDi, with Tech Pack High.
2007 Audi S8, with Rear Seat Entertainment, Quad Zone Climate, DAB/DVB and electric blinds. ** sold **
