As above folks,
Has anyone done this conversion to a FL S8 currently fitted with Brembo's? Don't need an upgrade, just weighing it up as I need to refurb my existing calipers Aside from cost, is their any reason why I shouldn't do this? Happy with current brake performance so this would largely be form/bling over function I was thinking of using rS4 calipers with w12 Phaeton discs which are much cheaper - would these or rs4 discs be a straight swap? Do you need adaptors and/or hoses ? Is there a weight gain in using RS4 calipers? Does the brake bias change with rs4 front calipers alone? Would I need to upgrade the rears to reset the bias? I see urquattro.net via eBay has a kit for the D2 that uses rs6 calipers and what looks to be phaeton discs for £1600- I think this could be done slightly cheaper as they charge £500 for the genuine VW phaeton discs alone. http://m.ebay.de/itm/380328707729 Apologies for all the questions, just trying to see if it's a bolt on upgrade and if so, what are the downsides (if any, apart from cost).
Shirish: 2001 S8 |
