Old 16th February 2009, 03:14 PM
Zip's Avatar
Zip Zip is offline
Question Water temperature...
...again, because I don't know what it used to run at, but I could have sworn it was pegged at 90degrees on the guage regardless of speed and air temperature.
Seems to be 10degrees lower at the moment - all the time.
Is this normal? Faulty t-stat?
Thanks,
Zip
2002 S8 FE
Old 16th February 2009, 05:09 PM
Sounds like faulty thermostat.. but if it never moves up beyond that, then likely sender.
Old 16th February 2009, 05:56 PM
If its stuck fully open then it would not reach opererating temprature as it needs to open further than 90 C to cope with very hot days.
Old 17th February 2009, 08:00 AM
Thanks,
Zip
2002 S8 FE
Faulty temperature sender is common - So common you're local Audi garage will have them on shelf in stock. They're about 30 quid and 10 minutes tops to fit....
Its called a 'dual temperature sender' as it has two independent sensors, one is used for the Engine ECU and one goes straight to the instrument cluster....
I can dig you out a part number, but from memory the Audi parts guys know it as the 'green one'
Old 17th February 2009, 03:58 PM
Zip's Avatar
Zip Zip is offline
Question So what temperature(s) should I be seeing...
...is a fairly constant 90degrees about right?
Zip
Old 17th February 2009, 04:12 PM
Mine has been rock solid 90 since i bought it no matter what I do.
Old 17th February 2009, 04:17 PM
Zip
Yup, in fact its documented somewhere that if its 90 degrees +/- 10 degrees it still shows 90 degress...... I guess it looks pretty 'straight up'..
