Old 30th June 2016, 09:25 AM
Vincecoleman Vincecoleman is offline
Default Self levelling rear suspension
I have leaking self levelling rear shocks; I've ordered some standard shocks and springs, is there anything else I'll need?
Old 30th June 2016, 10:50 AM
I'm going to keep my car, so I'd change whole rear suspension in this situation. Arms, stabiliser, all bolts and nuts, everything except subframe. But maybe subframe as well
As a bare minimum I'd change all parts that I'll need to remove from the car to do this job.
Old 30th June 2016, 11:17 AM
cheers, I appreciate that, think I phrased the question wrong; are there any additional parts req'd?
Old 30th June 2016, 02:38 PM
You will need everything that goes on top end of shock absorber - protective caps, bump buffer, bearing, any cups, spacers, nuts and washers.
Old 30th June 2016, 05:57 PM
Ok cheers, ill dig up some exploded diagrams. Are there any on this site with self levelling so I can compare?
Just want to get this beats mot'd so i can play!
Old 2nd July 2016, 06:11 AM
Last question, whats the best bet, have a return pipe made up or just cap off?
Old 2nd July 2016, 11:42 AM
I think most people just cap it off.....
Old 20th July 2016, 09:09 AM
Just for those undertaking this in the future;
if you buy secondhand shocks from a8parts they come complete with bump stops etc. you dont require anything else other than springs.
the supply and feed pipes are male and female so can just be connected together to close the system.
all in all fairly simple, although we had to make our own spring compressors as the space is so tight!
