Old 30th July 2017, 01:35 PM
It certainly is
The mounts were £45 each, and there are 8 of them - one top and one bottom on each corner. Bizarrely 7 in stock in the UK, and one had to come from Germany
I'll check whether the tool will fit the rear bushes later Those look to be about the same price each as the fronts but there are only 4 of them.
Old 31st July 2017, 02:54 PM
The rear bushes are a different design so this tool won't fit them. I could certainly look at making something though if you do want to replace them. I'd just need a bush to work with
Old 31st July 2017, 05:22 PM
Ah, that's a shame. Thanks. Probably be a few months before I have the job done so I'll let you know nearer the time.
Old 5th October 2017, 09:21 PM
Another new thing - a tool to remove stuck ABS sensors without damaging them.
Start with some thick-wall alloy tube
Turn it down to 17.5mm - just smaller than the sensor
Trim to length
Complete
This is how it works
Old 5th October 2017, 10:31 PM
11 out of 10 for ingenuity.
I need to show this stuff to my daughter, who is an engineer. Though Civil not Mechanical, so really big stuff in the ground!
This is one she did earlier:
Old 6th October 2017, 12:06 AM
That’s just showing off, LOL.
Please let her know I always admire that whenever fortunate enough to be passing through.
Old 6th October 2017, 07:06 AM
That is impressive
Old 6th October 2017, 09:40 AM
She led the design on all the groundworks stuff, including IIRC access roads, drainage, foundations, services etc.
A separate team did the building structure (it's an unusual space frame) and others again the contents/rides.
Did a similar job on this, though no longer involved and construction is far from finished:
Anyway, I'm digressing. Back on topic I'm finding this all fascinating and the skill levels MJ uses are amazing.
