Old 24th July 2017, 06:44 AM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
Anyone have issues communicating with the instrument cluster?
Fitted clock module last night and tried channel 19 adaptation thru obd11.
Would either give me a 'module not responding, check ignition'
On the couple of occasions it let me in, it would sit for ages, eventually giving me a time out error before showing the code
Thoughts?
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 24th July 2017, 07:57 AM
notorious notorious is online now
Check in ELSA adaption channel for your car.
Can be different for older cars.
Also, use latest VagCOM version.
Old 24th July 2017, 08:17 AM
Ameiseuk's Avatar
Hmmmm, I have niether
Could anybody with ELSA on here check it for me (or is it not that easy?)
Daily drive:
Current 'Project':
2000 Audi S8 FL
www.whall.co.uk
Old 7th May 2018, 11:47 AM
Just wondering if anyone else has lost their radio clock signal in this weather?
Mine disappeared a few days ago and I noticed that a radio-controlled wall clock in our house is showing the right minutes but wrong hour!
Old 7th May 2018, 08:25 PM
Mine’s been OK and it was around 26C here today
Old 7th May 2018, 08:49 PM
All tip top here. Never ever lost signal.
Old 8th May 2018, 04:06 PM
Ameiseuk's Avatar
I've one of those Junghans radio controlled watches....right minutes, 3 hours behind at the mo.
Display warning no communication for 4 days
Daily drive:
Current 'Project':
2000 Audi S8 FL
www.whall.co.uk
Old 8th May 2018, 04:27 PM
Both my car clock and house wall clock got a signal and are correct today.
I still think the weather has played a part, disrupting the signal.
Old 8th May 2018, 05:23 PM
Note that the newer "Radio" clocks work on a higher frequency than the first ones. Here in England Rugby Clock is the best to use.
I don't have one in the Audi but my house clocks and my watch are keeping correct Date/Time with Rugby. I also have a travelling alarm clock that is tuned to Germany and that is still correct.
Old 12th March 2020, 09:39 AM
Interesting (or not?) little footnote to this after a long thread snooze.....
The other day my S8 didn't want to start, it hasn't been used much lately, just the odd short run at night, and the battery wasn't quite up to starting. It turned over sluggishly then gave up. Down to about 12v when tested afterwards.
After an overnight on the battery charger it was fine, but the dash clock had decided to reset back to 1999. (Cue: Prince https://www.youtube.com/watch?v=rblt2EtFfC4 )
I just left it to resync via the radio receiver but when I next used the car it was an hour ahead, so either on BST or more likely CET.
Easy enough to adjust by an hour with the little menu control by the handbrake, but I can't recall if this is normal? I'm pretty sure it sorts itself out in Spring and Autumn when the clocks change.
