Old 1st June 2018, 07:54 PM
Energybutton Energybutton is offline
Default 360mm D3 front brake upgrade
Hi all,
looking for a bit of advice, I've just been told the front calipers on my FL A8L are sticking, I've been doing some research and see it's possible to upgrade to D3 360mm calipers however the guides I see seem to only link to Napa brake discs with no reference as to what model they come from, is it just a case of picking up D3 360mm calipers, discs and pads? Also does the standard D2 flexi line work with the D3 calipers?
Any help would be appreciated
Old 4th June 2018, 05:33 AM
27litres's Avatar
27litres 27litres is offline
See here:
Foreign forum click at your peril
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 13th June 2018, 08:58 PM
Thanks for the link, I had seen it before however since the D2 disc specs had broken links and I couldn't see them I wasn't able to make a decision, however I tried Zimmerman's website and was able to determine the disc height was the same for both the D2 and D3 models. Once confirmed I purchased D3 360mm discs, pads and 2 pot calipers which all mounted up perfectly with only a slight modification to the locating pins on the D2 brake hose and splicing the old brake pad warning connector onto the new pads.
I'm yet to drive the car yet so cannot comment on the stopping power, but they certainly fill the stock 17's I have on my A8!
I'll leave this information here in the hopes that someone else can use it in the future.
Tags
audi a8l d2 d3 360mm
