Old 13th October 2018, 07:34 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Yeah my cobbler was happy to do, touched it on his grinder and immediately took it off and gave me back and said the metal was too hard and would damage his cutter.
I hadn’t thought of that. I presumed the replacement blade would be made of cheese, so the thought didn’t cross my mind. This cobbler said she wouldn’t redo it or be responsible for bla bla, I said it’s fine. I won’t come back if it doesn’t work. I then went back to her about 5 minutes later, cos it wouldn’t work in the ignition...
She redid it a touch and boom, all was well.
2007 Mini Cooper S R56
Old 14th October 2018, 06:09 AM
Some that sell on aliexpress are happy to cut a blade from a picture you send them if required.
Old 11th January 2019, 07:06 PM
MattyV8's Avatar
MattyV8 MattyV8 is offline
Default Success!
Finally replaced my key fob case - total cost for new case with gaskets, battery and screws plus little audi badge on front - £9 delivered. The key doesn't feel cheap as I thought and actually looks oem.
Really easy to do, take the badge off, unscrew the screw then pull apart. There are 2 little screws at the bottom which need to be removed to get access to the circuit board. Put the new battery in and put back together.
I used my old key with the new spring and button so still looks new.
Pressed unlock and worked perfectly. Car sensed keyless features too. I put it in the ignition and turned on and off just to be sure.
ID:	20656   Click image for larger version
2006 Audi A8 4.2tdi Sport
Old 11th January 2019, 07:20 PM
Johnmed's Avatar
Looks nice. Got any links for the product(s)?
Old 11th January 2019, 10:56 PM
H-M3 H-M3 is offline
A step by step photo would’ve been good for us numpty but well done
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 13th January 2019, 07:15 AM
MattyV8's Avatar
Here you go
https://rover.ebay.com/rover/0/0/0?m...2F123498257778
Old 13th January 2019, 07:32 AM
Johnmed's Avatar
Cheers Matty
Old 13th January 2019, 09:48 AM
MattyV8's Avatar
I never thought of doing that but it really is as straight forward as -
Take Audi badge off key using thin screwdriver or knife
Unscrew the screw that is behind the badge
Pull two pieces apart
Undo two screws at bottom of circuit board half
Pry out the circuit board
Then do the same with the new key fob case and transfer the circuit board and battery over. Everything fits as it did with old case so can't go wrong really.
Only thing I would add is I didn't need to screw the two screws at the bottom on new case. They are provided but I found it wouldn't clip together with them in. Not sure why.
Old 13th January 2019, 10:21 AM
Johnmed's Avatar
Thanks OP, don’t feel like you needed to do more. Not everyone has the patience or time to do guides. I always consider doing a guide myself, when doing little jobs.
Then, the wife is nagging, the kids are wanting to ‘help’ and I’m not in the mood to even do the job in hand, never mind the guide.
Old 13th January 2019, 10:56 AM
I'm not at all good at that either, the biggest problem is that it's only AFTER I've done a particular step and realised what the critical item is, that I realise I should have illustrated it, but it's usually too late!
It's only when you've done it several times that you know how to guide others.
(Now taking a boot lid apart I can do in my sleep...)
