Old 2nd October 2010, 08:41 PM
Default Sticky Handbrake mechanism - Rear caliper.
Solution: Hit with your biggest hammer until you feel better and return to MOT station. Initial reading 179 O/S, 11 N/S . Post hammer both sides equal.
Put the new caliper on yesterday and now I only have 2 clicks to engage the handbrake compared to the full extension I was using so the lesson for the day is if your handbrake comes up more than two or three clicks then something is broken somewhere....
Bill
Old 3rd October 2010, 09:40 AM
CliveH's Avatar
CliveH CliveH is offline
I had the same problem with the S2, in fact both rear calipers were not returning to their stops - solution : 2 new rear calipers, no hammers were used and no calipers were harmed in the process...
Present: S4 B8 avant, fully loaded, MRC Stage2, Milltek non-res, KW springs
Past: S8 D2 FL, S2 ABY coupe, RS6 C5 saloon, RS4 B7 saloon, S4 B5 saloon, S4 B6 avant, all gone but not forgotten
Old 3rd October 2010, 12:39 PM
christhompson's Avatar
Must be an Audi design problem. My 90Quattro suffered from seizing handbrake quadrants - usually noticed at MOT time! As I had the car for *many* years I started to replace them proactively whilst being serviced etc. Result no further problems. In the interim, every time you can get underneath the car, give them both a spray with WD40 or similar.
Chris
Old 3rd October 2010, 12:52 PM
Strangely when I came to do my brakes last year the rear calipers had already been replaced but they had left old discs in which were a fraction of the cost - seemed like false economy to me for the sake of about 50 quid to do both sides the plus was i was expecting to do discs and calipers all around having read about rear caliper issues so it saved me the rear caliper costs
Old 24th October 2010, 09:45 PM
My rear brakes work properly but If I use the handbrake then the n/s sticks on.
I put took the wheel off and spent a while applying the handbrake and then using a hammer to release it as the return spring could not release the h/b.
Even though I splashed a load of WD-40 on it as I worked, it still sticks if applied.
Is there more I could do apart from replace the caliper? It's an early FL so it's got the pukka Brembo brakes...not in stock at A8 parts.
Old 25th October 2010, 07:52 AM
Simon,
All rear brakes are Girling. It is more than likely to be corrosion of the piston which means it wont sink back into the caliper. Stop hitting it with the hammer, disasemble from the carrier and remove the dust seal. If the dust seal has failed Moisture will have got in.
The temp repair procedure is here.
Old 25th October 2010, 03:32 PM
I think you have two options..
1 - As Mike says above..
or
2 - You need a bigger hammer
Old 27th October 2010, 06:01 PM
Conan.
By George, I think you've got it!
Your explanation makes perfect sense as plainly what I was doing with the hammer (hitting it), would not affect the way that the piston travels.
I'm just surprised at Audi. I'd expected these pistons made out of Stainless.
On second thoughts, how come the 'pedal' brake don't stick on then?
Is the handbrake not the same piston?
Old 27th October 2010, 08:11 PM
It is and you can test it by driving for a mile or two and feeling the disks 'carefully' with a wet finger, It will hiss on a stuck calliper and warm gently on a properly working one.
Old 31st October 2010, 08:02 PM
Conan
The brakes only get hot if I've used the handbrake.
They don't bind at all otherwise, so it's a problem with the h/b mechanism.
But how to fix it???
