Old 17th February 2022, 01:36 PM
Their life is short enough as it is without adding poly in to the mix. I'm not sure it would gain anything in handling, since there isn't much movement in the rubber anyway, and poly under that much movement wouldn't last very long. They are used on loads of things so I think it is still best to use good quality rubber versions.
There used to be a balljointed version but that superceded to the rubber one because it lasted even less time, and was a complete pain to change.
I think the offset may explain why some cars just eat through them and some don't, but its very hard to tell when they are on the car, especially with it jacked up.
Old 17th February 2022, 06:50 PM
Finished the rest of the floorpan
The sealant in the engine bay is working nicely
Before putting the engine back in I will replace this foam while it's easy to get to
While working on cleaning the old foam, I realised I hadn't done Botang's hole On this one it was half buried under the bitumen sound deadening which made it extra difficult as I had to chip that away and then clean off the residue with acetone on cotton buds Its a bit like wallpapering the living room from the garden by reaching through the letterbox...
Ended up with it nice and clean though so I can fill it in tomorrow and put the engine back in.
ID:	27906   Click image for larger version
ID:	27907   Click image for larger version
ID:	27908   Click image for larger version
Old 17th February 2022, 07:50 PM
Yeah same on Big Red too, and a couple of others. The B5 links should sort it and they are the same price.
Best wait until you can confirm?
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 17th February 2022, 08:10 PM
Yeah the B5 parts will hopefully be here on Saturday and I will post pics of how they fit
Botang's grommet:
Old 18th February 2022, 05:32 AM
Botang's grommet:
We’d expect nothing less by now!
Your perfection level has just gone up again!
Old 18th February 2022, 12:29 PM
Mine is currently looking like this:
Paul
Gosport UK
Honda Jazz
Old 18th February 2022, 06:38 PM
No significant progress today as I have a migraine
Botang's grommet fitted fine. Its probably watertight on its own, but I've covered it in seam sealer anyway. This is not the car on which to experiment with water ingress!
New foam on the hvac inlet
Hopefully I can put the engine back in tomorrow.
ID:	27920   Click image for larger version
ID:	27921   Click image for larger version
Old 18th February 2022, 08:28 PM
Ronin Ronin is offline
with botang's hole I find it harder to photograph than to do work on it
Old 19th February 2022, 08:24 PM
Very true ^
I put the engine back in this morning
The A4 links arrived - top, compared to the D2 on the bottom. You can see the extra spacer they have
and they fit perfectly Part numbers are 8D0411317D and 8D0411318D (they are handed)
Starter terminal box. I've taken to filling these with waxoyl as its waterproof but not as nasty as the thick grease the factory used.
Put the washer bottle back in and tested for leaks. Of course it did leak, from the level sensing grommet on the windscreen washer pump, which they always do when disturbed, hence testing. I can not get this one to re-seal so I'll print a new grommet.
Mostly back together. Suspension and front panel tomorrow.
ID:	27923   Click image for larger version
ID:	27924   Click image for larger version
ID:	27925   Click image for larger version
ID:	27926   Click image for larger version
ID:	27927   Click image for larger version
ID:	27928   Click image for larger version
Old 20th February 2022, 01:54 PM
Oddly I find myself staring at the images of this engine for ages, thinking maybe office wall art?
Is that expansion tank super cleaned like the screen wash reservoir? I have noticed in a few other posts the coolant is pink? I am beginning to think the garage that changed my water pump, which I supplied with the requisite amount of G12 coolant a few years back, didn't put the G12 in. The coolant is 'clear-ish' but starting to turn the tank brownish from the inside
Paul
Gosport UK
Honda Jazz
