It's been a long time since I switched out my stock ignition coil for the D3 ignition coils. How do I remove the pig tail connector for the ignition coil? I tried pushing down on the center tab and tried to pull the connector off and it didn't want to budge. I don't want to break this connector, so is there a trick to disconnect these?
2001 S8 (build date March 16th 2001) Brilliant black with oxblood red/black interior. Mods prior to my ownership: 01E 6 speed, carbon fiber trim, bi-xenon, aftermarket muffler with x-pipe, tinted windows, non-tip steering wheel, Spal electric fan. My mods: Oxblood red interior, LED interior lights, D3 ignition coils, new window tint, tip steering wheel with new S8 emblem, mk1 TT steering wheel air bag, mk1 TT 6 speed shift knob, new shift boot. |
Those latches are all the same on loads of connectors and totally counter-intuitive.
I know if you look at one once it's off you'll immediately see how they work. Once you do whatever is needed (and it's VERY easy) they just slide off with minimal force. IIRC you press on that exposed tab INWARDS towards the centre of the connector and off it comes. I vaguely recall that the exposed tab is the end of a length of plastic with a catch on the other end, hinged half way along. Press on the tab and the catch lifts off. BUT I could be wrong.... It really is easy when you get it right so DO NOT FORCE! It might help to gently push the connector on as you do that to enable the catch to open. Try putting a finger behind and a thumb on the tab and squeeze while pushing on gently then keep squeezing and pull off.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 14th May 2022 at 08:22 PM. |
Thanks for the advice, I will give it another try. At first I didn't want to force anything and break something.
