Old 3rd December 2024, 06:01 PM
Default For sale electrical coolant pump and hoses for D3 parking heater retrofit
I bought these when I had D3 , but sold the car before got them fitted, kept the pump thinking I might need the pump for Q7 but turned out it already had the pump so it's been sitting forgotten in cupboard and is unused and never been fitted. The pump with the cable was around £130 when I bought it, correct housing was about £30, hoses about £15 each and couple pounds for extra hose clips. Original housing is also included. Would still need a 20mm connecting pipe for houses, I did have plastic one but I was planning on getting metal instead and don't know where the plastic one has gone, will also need band clamp for pump, not sure if these are available to buy, I was going to make my own. There is a rubber sleeve on the pump already. This will be enough to get parking heater working manually without engine running or on timer from MMI. If you want remote control, it will need additional parts. You can find a fitting guide here: https://forum.a8parts.co.uk/attachme...0&d=1537262841
It cost me close to £200, would like to get £150 for it. Pictures attached.
ID:	30443   Click image for larger version
ID:	30444   Click image for larger version
ID:	30445   Click image for larger version
ID:	30446   Click image for larger version
