For Sale and Wanted - General Posting for buying / selling your own personal non vehicle related items |
Fully working please, preferably one where somebody hasnt forced the piston back
The piston has to be pushed back when fitting new pads
. Nite Blue 3.0L SE Quattro |
I know, found out today, the previous owner had changed the pads, I checked this when visually checking the car over prior to purchase, the pads are 8mm thick but vagcom only reads 3mm and is throwing the pad warning constantly. Vagcom won't let the setting be over ridden so I'm assuming the pistons skipped a thread or something causing the misread ?
I can only assume the previous owner pushed\forced the piston in withou resetting ![]() Only had the car x3 weeks and this is the first thing I've found so if that's all there is I've got off lightly I think |
The piston can't skip a thread. Why not switch off the EPC using Vag-com then remove the pads and push the pistons back in and reset and see if that clears it
There is a procedure to re-calibrate the read brakes, it's not as simple as just changing the figure from memory.
Ah, I have a cable on the way so when it arrives I'll be doing it myself, cheers for the guide i'll, I have a friendly garage that allowed me to use there vagcom today and I did do the reset but I didn't disable the epc, hence I didn't resolve it assuming it was a calliper needed.
The caliper and the EPB are two separate items
