Old 26th May 2013, 11:18 PM
Default D2 FL MOD: Pre-FL switches fit perfectly in the dashboard blank
Discovered great stuff today: Pre-FL switches fit perfectly in the dashboard blank provided.
This opens for me whole new scope I can have a switch to blink fog lights independently of headlights or parking lights....
No... better idea! When I finish installation of my Hormann garage doors I can put there a blinds switch and open garage doors: http://www.audipages.com/upgrades/garagedrinstall.html
Blinds switch pictogram actually looks like a garage door
Old 27th May 2013, 12:58 AM
71camaro 71camaro is offline
Wish I had a garage door, I'd do that for sure.
Old 27th May 2013, 08:47 AM
I love it when a plan comes together!
Old 30th May 2013, 01:33 PM
Garage open/close door button installed in dash.
No automated garage doors yet though... But we'll get there.
Old 30th May 2013, 01:37 PM
Great job and brilliant idea!
Is this where the headlight adjustment would have been?
Old 30th May 2013, 01:53 PM
Yep. Any Pre-FL button can be installed there.
Those pre-FL buttons are great -- better to touch than FL ones.
Old 30th May 2013, 02:15 PM
tintin tintin is online now
Hmmm....very interesting. I too have a Hormann door, but didn't know you could do this with the '8, but very keen to find out now. Then I can keep the two existing remotes with the other cars :-)
Old 30th May 2013, 03:21 PM
Have you opened this link http://www.audipages.com/upgrades/garagedrinstall.html ? It allows to remove button from any remote and connect the 8 button.
Hotmann supplies one button thing that you can insert into cigarette lighter. Organise a cigarette lighter for it somewhere under trim and connect 8 button with horman thing via methodology in the link.
Old 5th October 2013, 07:21 PM
A small writeup.
Buy Hormann BiSecur HSZ 1 BS cigarette lighter transmitter.
It comes with quality build-in lithium 3v battery, which will last many years
Turn head of transmitter and it will open. If it won't just help a bit with a thin flat screwdriver.
On a small circuit there's a pushbutton.
Take sharp knife and pry it off. No even need to desolder.
You will see two rectangular poles which the pushbutton connects together when pressed.
Take your soldering iron and just solder two wires to those poles.
Now if you want to open/close/stop door you need to connect those wires together.
Case goes back on
Wires are fixed with a cable tie
The whole thing is wrapped with 3M insulation tape and then with Certoplast.
Final product is placed behind fuse panel in driver footrest. There's plenty of space there and good access when I'll need to change battery in 15 years.
Other end of wires are connected to pushbutton on dashboard. Works beautifully.
P.S. If you don't know what soldering iron is I'd suggest to purchase Hormann recessed radio transmitter called 'FUS 2' which has screwdriver terminals.
It is designed for in-house installation to control garage doors from your home with a domestic light switch. It can run from a 9v battery and can control two doors.
http://www.torteam24.de/2-kanal-funk...-2-p-2223.html
Just connect button on your dash with FUS 2 terminals and you're done. FUS 2 is bigger than cigarette lighter transmitter and perhaps wasn't tested for car use by Hormann, but I'm sure it won't be a problem. Just find a place to hide it under the dash.
ID:	6803   Click image for larger version
ID:	6804   Click image for larger version
ID:	6805   Click image for larger version
ID:	6806   Click image for larger version
ID:	6807   Click image for larger version
ID:	6808   Click image for larger version
ID:	6809   Click image for larger version
ID:	6810   Click image for larger version
ID:	6811   Click image for larger version
Old 6th October 2013, 08:40 AM
Great write up! I wish I had garage now! This is a great mod.
Dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1992 Mazda eunos v spec
1976 Reliant Kitten
1965 Porsche 911
