Old 18th November 2013, 07:57 PM
Way above my pay grade, but given that the left parcel shelf speaker and left rear door speakers are a matched unit (woofer, bass and treble?), similarly on the right, I wouldn't be changing any of it without expert car audio advice.
Old 18th November 2013, 08:54 PM
If you were going with a good set, then you could swap the lot and put a seperate sub amp, or even a completely seperate amp in, but there's a pile of wiring to sort.
Old 18th November 2013, 09:01 PM
nickid's Avatar
nickid nickid is offline
Going to replace them all starting with the rear ones. I have just bought an amp also to run the rear speakers, so I just need to figure out the best why to run it
Old 18th November 2013, 09:33 PM
I'd splice the rear door amp into the connections that feed from the shelf speakers, saves on cabling and pulling as much trim off.
Old 18th November 2013, 09:36 PM
nickid's Avatar
do the rear doors have those type of speakers with their own amps too?
Old 18th November 2013, 09:43 PM
Did you miss my earlier post?
Rear speakers are powered, have amps in them and then drive the rear door speakers.
Old 18th November 2013, 09:48 PM
nickid's Avatar
sorry I did read it just getting confused
Old 18th November 2013, 09:49 PM
Notorious kindly and conveniently posted a complete wiring diagram here, you can check that to confirm: http://forum.a8parts.co.uk/showpost....8&postcount=22
Old 19th November 2013, 01:05 PM
nickid's Avatar
got that. thank you very much
Old 19th November 2013, 01:46 PM
Hope it's useful, I saved a copy on my PC for reference.
I had a careful look at it when trying to sort out the pathetic sound from the rear and decided the amps were indeed built in to the rear shelf speakers (only) and took the covers off (and even took one out) to verify the wiring.
