I like the idea of build or progress threads of cars.
It gives me a record of what I've done and I can help others with their faults or ideas on what to do with. So here's one for my 06 3.0TDI A8 in Akoya Silver. Bought privately from a bloke in wales with full Audi Service history minus the one that he did last month. I'm going to pop to Audi in the coming weeks and check for any recalls, updates and see how much they want for servicing as I'd like to carry on the history is possible. The paper work was a little bit thin with the car apart from the MOTs and plate transfers. 01/2013 - Paint correction done on the rear wings both sides, roof repaired near the windscreen and a new windscreen fitted under warrant. 08/13 - Drivers outer trim halfway up replaced. 08/13 - New number plates and holders. 12/13 - New body molding and Diag of fault hand break. New calliper and electrical setup required. 02/14 - New calliper and break pads all rounds. Current list of things to repair: 1, Rear passenger footwell heater. 2, Passenger rear door speaker cover is cracked. 3, Passengers side rear blind trim won't stay down. 4, The auto rear boot needs a helping hand for the first inch then it takes over. Two pics of the car at the moment. I'll get better once its been cleaned. ![]() ![]()
[center] 06 3.0TDI Quattro: Options: Soft close Doors & Boot, Electric Blinds, Keyless Entry & Start, Bluetooth HandFree, Quad Zone Climate, APS+, 3 Spoke Sports Tiptronic Multi Function Steering Wheel, Heated Seats All Round, Black Leather Comfort Seats, AMI, Sunroof, Drivers & Passenger Electric Memory Seats, Auto Dimming Mirrors, Bi-Xenons AFS2, Dab, Digital TV, Reversing Camera, AV Inputs, Fridge, Solar Roof, TPMS, facelift rear lights, 3G, remote boot closure, Tow Bar. Last edited by ScottD3; 23rd March 2014 at 08:28 PM. |
Hi Scott, you may be able to fix the auto boot motor yourself like I did, check here: http://forum.a8parts.co.uk/showthread.php?t=6323
Alternative is to buy new motor for around £500... |
Thanks audifin.
I'll have a look at that when I got time. First time walking to the car at night and noticed the passenger exterior door handle illumination has stopped working. I used that door to open the car, so don't know if it's anything to do with that. I've not noticed it before.
First time since looking at the car I've been able to have some alone time with the car, a proper dig and VCDS scan time.
First, up some fault codes that I had when I got back from Bristol. 005658 - Glowplug for Cylinder 1 (Q10) P161A - 001 - Open Circuit 001025 - EGR System P0401 - 002 - Insufficient Flow 02126 - Central Locking Button; Exterior Door Handle 008 - Implausible Signal 00190 - Driver's Door Handle Touch Sensor (G415) 007 - Short to Ground 00192 - Rear Left Door Handle Touch Sensor (G417) 007 - Short to Ground - Intermittent 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent 00066 - Rear Right Footwell Heater (Z43) 012 - Electrical Fault in Circuit - Intermittent 00065 - Rear Left Footwell Heater (Z42) 012 - Electrical Fault in Circuit - Intermittent 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication - Intermittent 01300 - Control Module for Navigation with CD-Rom (J401) 004 - No Signal/Communication - Intermittent 01598 - Drive Battery Voltage 002 - Lower Limit Exceeded - Intermittent 02111 - Motor for Window Regulator 004 - No Signal/Communication - Intermittent 02126 - Central Locking Button; Exterior Door Handle 008 - Implausible Signal 02256 - Quiescent Current 001 - Upper Limit Exceeded - Intermittent 02272 - Quiescent Current Stage 1 000 - - - Intermittent Cleared all fault codes and only two came back. 00190 - Driver's Door Handle Touch Sensor (G415) 007 - Short to Ground 02126 - Central Locking Button; Exterior Door Handle 008 - Implausible Signal I'll do another full scan tomorrow after a little drive. I'll take a look at the two that came back but it looks like its just connection issues? Having a look around the boot sides I noticed this cable going down through the rear air vents. ![]() ![]() The HPI check came back saying it has a tracker, it could be that. I need to phone the tracker company to make sure but anyone got any ideas? The tool kit is looking a little sparse and needs filling up. ![]() I've got what I think is a Audi detachable two bar but I don't know where it is mean to go for storage. What am I missing? ![]() There is also this connection in the glove box. I've been told that it could be a Dension 500 gateway kit but I'm not sure. Can anyone confirm? ![]() It works fine with the iPod but I'm not sure how the USB or RCS connection works but I'll have more playing about with that later. There is a couple of little bits I need to pick up over the coming weeks but mainly I need to give it a good clean.
Looks like a dension kit in the glovebox.
For the tow bar, you're missing the polysterene basket thingy that goes around the screw for the spare wheel, which holds the towbar itself plus some other bits (have you got the key for it?) Bit of a crap tracker installation as that cable is very obviously aftermarket. The door sensors are probably failed, though you may be lucky.
I looked at the bar it self and there no sign of a lock. A8 Parts should have a spare basket and bits i'm missing from the boot? Quote:
Sensors expensive?
I don't think the door sensors are comically expensive, but I've never done one, they are a 'door apart' job though.
If the tow ball doesn't have a key/lock, then it's not the factory job, and that could be where the wiring comes from/goes.
I'll double check it later. I noticed the Audi logo on the ball cap but that could be got from anywhere. The electrics fold up and down, I've not seen that before on a aftermarket unit.
Some aftermarket ones do fold up and down.
Got under the car had a look at the tow bar.
Its a genuine Audi bar but the ball is a westfalia unit (how ever you spell it). No biggy, it clips and works, I'm happy but I would like the proper holder for it. Its currently rattling around the spare wheel.
