Old 31st March 2014, 08:04 PM
mikes2 mikes2 is offline
Default Instrument cluster warning lights
When I switch on the ignition before starting the car, what warning lights should I see on the instrument cluster ?
I see the immobiliser, EPC, ABS, airbag, handbrake but no sign of an engine management light.
Is this correct ?
2002 3.7 quattro sport (SOLD)
Old 31st March 2014, 08:08 PM
mannyo mannyo is offline
The engine light should be on before you start the car and then go out.
Manny
Past
Old 1st April 2014, 01:24 AM
My 1998 S8 and friends 1997 A8 did not have bulb in it an opening was covered with paper sticker from factory. Put the bulbs in and both working as supposed to. It is red CAT light in both not amber engine management.
Old 14th April 2014, 07:15 PM
Apologies for not replying sooner but thanks for the replies.
having scanned with VCDS, it would appear it's been removed to get it through an MOT at some point.
I've now replaced the lambda probe and all the secondary air vac hoses and the ecu is clear of codes.
Are the bulbs easy enough to replace ?
Old 15th April 2014, 10:36 AM
They are LEDs and not bulbs, so it may have just been taped over.
Manny
Past
Old 16th April 2014, 12:57 PM
Thanks for all your assistance.
Had the cluster out and apart today.
removed some black tape which was covering the LED.
