Old 7th May 2015, 04:54 PM
Lloyd Lloyd is offline
Default Wanted Wanted Wanted
Pre facelift D2 double din cage and trim Facia ( colour. It important as it will be getting painted )
Old 8th May 2015, 01:48 AM
Possibly one of the rarest pieces of A8 preface trim known to man.....
I once saw one bid > £600 on Ebay.de
Unless you have deep pockets, or an insane amount of luck, you might want to formulate a plan b
And painting it would be like biro-ing a pair of glasses on the mona lisa
Old 8th May 2015, 05:34 AM
There was fascia offered on forum at one time but likely long gone now. http://forum.a8parts.co.uk/showthrea...ht=double+ranj
I also seen PF double din fascia+cage on ebay for £150 but still it was too much for me.
Old 8th May 2015, 10:42 AM
Can't tell from the photos, but might be worth a phone call:
http://www.ebay.co.uk/itm/AUDI-S8-19...item4ae9a84c04
Old 8th May 2015, 01:28 PM
They were only available in the very last 1998 models, and then the facelift happened - That's what makes them so rare
To give it some perspective, I've seen only two in the flesh in the last 8 years, and I've seen a *lot* of D2s....
On the plus side, they're not handed, so you might have better luck searching German / French / Belgium Ebay...
Old 8th May 2015, 01:56 PM
Mailed already , sadly it's single din
Old 8th May 2015, 02:01 PM
I think I actually winced a little when I opened that link and saw this picture:
I must've been driving D2 8s so long now that I'm actually starting to empathise with them!
Old 8th May 2015, 02:05 PM
I have a fl cage double din and trim in birds eye maple if that helps
Old 8th May 2015, 02:29 PM
Facelift cages are quite common in comparison.
Fitting the FL cage to a PF is do-able (Theres a thread on here somewhere from when I did it a ___long___ time ago) but be prepared for a lot of headache as the climate module wont fit / work and buttons like heated window move. Also the fog lights and heated seats change. FL uses canbus, which the PF doesn't use so then you have to start generating canbus signals for speed / ignition etc for the climate module to work and really, that's easier done with a FL instrument cluster.
Its quite a big job.....
Old 8th May 2015, 03:04 PM
Nuisanceneighbour Nuisanceneighbour is offline
You mean one of these? Had it in a cupboard for a few years, finally got round to putting it in a week or so back. Good luck with your search.
ID:	10738   Click image for larger version
ID:	10739   Click image for larger version
ID:	10740   Click image for larger version
ID:	10741   Click image for larger version
ID:	10742   Click image for larger version
ID:	10743   Click image for larger version
ID:	10744   Click image for larger version
ID:	10745   Click image for larger version
