Old 29th June 2015, 08:03 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Default Anyone recognise this?
Wife reckons it fell from the near side door onto her foot as she got out of the 8. I'm not so sure...
2007 Mini Cooper S R56
Old 29th June 2015, 08:12 PM
Door hinge pin? from the lower bracket with 3 pins?
sorry just realised you have a D3 not a D2.
Old 29th June 2015, 08:34 PM
kele kele is offline
I think I have its identical twin! I believe it is from the front door pocket but I need to have a closer look at mine before I can say for sure....
2022 Mercedes EQC 400
2008 A8 3.0 Tdi sport, B&O
Old 29th June 2015, 09:52 PM
Johnmed's Avatar
Thanks for the replies.
Just had a butchers in the dark with a torch. Can't see where it may have come from, but don't have access to the near side at the moment.
Curious.
Old 30th June 2015, 07:05 AM
From memory the top hinge is the smaller one and could have a pin like that, but it does look small in the photo. If it is from the hinge assembly it'll be obvious, but be careful as the door could drop. The top hinge pin has a grub screw.
I'd expect the pin to be pushed in from the top so even if it were to come loose it could never fall out, but that might not be the case.
Also worth checking the glove box hinge?
Old 30th June 2015, 07:37 AM
I think its the door pocket stop.. normally has a white rubber grommet over the top.. if you pull your pocket out you will see them on there ... i could be wrong of course ... infact a strong possibility id say
Old 30th June 2015, 08:48 AM
Johnmed's Avatar
Seems I've lost the pin. Oh well. Maybe we'll never know!
Old 30th June 2015, 09:30 AM
Johnmed's Avatar
Well, the hinged door pocket is loose, so that's where the pin came from. Best try and find it.
Old 22nd July 2015, 03:46 PM
Johnmed's Avatar
Ok. I found the pin again, and returned it to the hinge of the door pocket. Turns out part of the plastic hinge had snapped.
All back together again with some loctite and zip ties. (for now at least)
Old 22nd July 2015, 07:29 PM
Ok. I need to put mine back also. Did you have to remove the door card or the door pocket?
