Old 23rd July 2015, 01:02 PM
Originally Posted by Nick Jones View Post
It's off! Big breaker bar did the job.
That's a relief!
Now I can investigate why this wheel (Right rear) has 4.5mm toe in and 2º negative camber....
Nick
Hopefully it's not bent. Drifting and hitting a kerb
Camber on the rear is easily adjustable but wouldn't think 2 degs neg is out the way, race car.
Toe can be adjusted too in theory by an bolt but age, rust and wear may mean its going to be tighter than a locking wheel nut on an A8.
Old 23rd July 2015, 04:15 PM
Car definitely has an "interesting" history looking at the various bits of physical evidence!
Alignment issues manifest as a pull to the left. After this mornings measuring session the main issue seems to be rear toe.
4.5mm (!) toe in LH rear and 0.5mm toe out RH rear. This kicks the rear out to the right giving the apparent leftwards pull. Camber is 2º-ve on left and 0.0º on right.
Camber is no problem to adjust and I have a rudimentary gauge that shows I can get that to 0.5º -ve both sides. This will help the toe but not fully correct it. Road test after the camber adjust shows the pull to be reduced but not gone.
The toe adjustment mechanism (designed by a lunatic presumably) is rusted solid........ Joy. Various of the bushes look a bit weary also. Not sure if these are available separately?
Really needs the whole rear subframe dropping out, dismantling, blasting, painting and reassembly with new bushes. Low probability event that!
Nick
