have you also checked the operation of your manifold flaps to make sure they are not stuck / seized and restricting performance.
How do i check the manifold flaps?
Yeah its being read this evening later on. Drives fine around town and u 6k rpm lol |
Pop the plastic engine cover off and look at the two bellows on the front of the engine and the linkages from them. Check nothing is broken and that you can move them by hand.
Get someone to start the engine while you watch them, both bellows should collapse due to vacuum and move the linkages which operate the manifold flaps (inside). It looks a bit like this though you'll probably have the shorter linkage arms: ![]()
System too lean bank 1 and 2. Any idea on cause? Lol
Low fuel pressure, faulty MAF, vacuum leak to get you started.
Cheers ill have a badgers
Whn you coded out the SAI, did you remove anything? Mine is playing up, and id rather code out than have to remove if possible
I don't think you have to remove anything, as the ECU will no longer care about the signal from N112 or try to run the SAI motor for a few seconds on start up. I'm just guessing that's what they did, I'm not a coder (and the motor was already gone when I got the car back). The other possibility is that they just remove the 'trouble code' from the ECU, which would mean the startup routine would still try to run the pump, just not register a fault code when it finds the pump not working.
I just wanted all that junk out of there ![]() I can clean the airbox much better now when changing the air filter. Last edited by Goran; 4th August 2015 at 12:18 PM. |
