Old 10th May 2012, 09:29 PM
Default Retrofit ACC
Found this thread on audiforums.us
Full explanation of retrofitting ACC to a D3
http://audiforum.us/threads/a8-adapt...retrofit.7800/
Old 10th May 2012, 09:32 PM
seen it before, I would love ACC but looking at the retrofit requiement its out of the question for me, next car maybe
Old 11th May 2012, 12:00 PM
sloss's Avatar
sloss sloss is offline
That's a serious bit of work! Respect!
However I'll be looking for ACC already there for my next car I think.
Set the Sat Nav, Set the ACC jump in the back and make a cuppa - sorted!
Old 12th July 2015, 11:46 AM
Turbo Tony's Avatar
I thought this may be a useful thread to bump for Del, who is soon planning to do this retrofit (and give me some VERY detailed instructions!)
Storytellers Villa Orlando
2008 Audi S8
Old 14th July 2015, 06:32 PM
Yeah its a good thread that, mine will be better
Old 15th July 2015, 07:20 AM
mannyo mannyo is offline
Still need to get my factory fitted ACC calibrated properly after getting it working some months ago.
Del, if you have a way of avoiding the dealer to do this then let me know.
Manny
Past
Old 13th August 2015, 05:47 PM
Have you had a look in the basic settings to see what your current angles are?
Although VCDS is vague, it does clearly show two boxes with angles in them, mine was showing 2.xxx on one and 0.1xx on the other I suspect the 2 degree one is vertical alignment because the car seems to sit close to the car in front.
I done basic settings on both and tweaked the sensor up by a bit and will see how I get on.
According to Elsa on the matter the radar should be with in 0.5 degrees to run happily so thats my mission.
I will keep you updated as I go and hopefully figure out whats what to write a label file to make it easier in future.
