Old 27th October 2015, 02:46 AM
laketahoequattro laketahoequattro is offline
Default Coolant temp a steady 105 Deg?
So when I re did my cam belt 200 miles ago I replaced everything cam belt related to also include a new thermostat. I hope I did not bite myself by purchasing a Mahle Behr Thermostat (supposedly 82 degrees C) over an OEM one.
Using the recirculate and Up button on the Hvac I have been monitoring my coolant temps. The temp will rise to 105 - 110 degrees while on the freeway and then settle back down to 99 - 101 degrees while at idle. I have never seen the temps get over 112 degrees.
I know this is way too hot, it is supposed to sit around 93 degrees. All I can think is that it is a thermostat, clog, or air bubble in the air system. I do not think it is a sensor issue. Heat blows fine thru the hvac system, and there are no codes in the hvac.
Any ideas? Thanks in advance..
2003 A8L Build Thread
D3 Turbine Reps – S8 Mani
2002 Allroad Build Thread
2005 Color Match - TDI 01E - TTV LWFW - RS4 PP - BW K04s - Stg 2 WMI - WB- AWE DTS - EFK - H-SPORTS - IPP Arms - S6 Alcantaras - 4K LB Hitch - V1
Old 27th October 2015, 10:01 AM
oldnick oldnick is offline
I may be wrong but something in the back of my mind says that the map controls the temperature at 105C as normal running temperature ; however , at full throttle , the temperature is reduced to 90C as an anti knock measure
sounds to me as though you are in good shape !
Old 27th October 2015, 10:17 AM
knew I'd read it somewhere
http://www.s4-mtm.com/images/RS4V8-StudyGuide.pdf
read the whole thing if you have time ...well worth it !
Old 27th October 2015, 03:10 PM
Yes however, that is for the new 2005+ engines. I have a 2003 belt 4.2. It does not have the electric thermostat like that FSI one.
This is me: http://www.kpematop.com/S6/V8-5VEngine.pdf
Old 27th October 2015, 03:15 PM
Do you have access to a digital thermometer so you can take readings straight off the engine before you go down the route of pulling it to bits.
Just wondering if the sensors borked.
Old 27th October 2015, 03:35 PM
I do have a type K thermocouple wire I can use on my dmm. Where should I probe?
Old 27th October 2015, 04:18 PM
in the coolant stream would be good but can you get it on the block close to the thermostat?
Old 27th October 2015, 04:27 PM
I may be able to put it on the metal thermostat housing
Old 27th October 2015, 05:48 PM
aha , always a good idea to state exactly what you have
http://www.cpp.edu/~bvnorum/ebahn/c5...drain_fill.pdf
but according to this you should WARM the engine to around 100 when filling or topping up , which still suggests to me that that is the correct tick over temperature , and that the only difference with the later engine is that it doesn't have the anti knock temperature reduction programme
personally I would still be content with what you have , but you pay your money and make your choice !
Old 27th October 2015, 06:31 PM
I am just concerned because it is only 16 degrees here and high coolant temps. What happens when it is summer you know? I do all the work myself thank god or I would be broke haha
I did not follow that bleed procedure verbatim, so I will repeat those steps
Tags
coolant, high coolant temp, thermostat
