Old 27th October 2015, 06:13 PM
Palmer Palmer is offline
Default Slow window after replacement.
I had a cracked outer pane when i bought the vehicle. I sourced and fitted a new window. Ever since its been alot slower than the other windows.
Its quick at the top and bottom few inches but the middle section it slows right dow. Also a very loud clunking when you change the window direction.
Any ideas what it could be?
Old 28th October 2015, 12:48 PM
DJS DJS is offline
There are few adjustments you can do. It might not be fully square in the runner. Also try lubricating the runner as it might be dry.
Old 28th October 2015, 08:16 PM
Is this the runner u can see on the left hand side when the windows down?
Iirc they were all dry! White grease?
Old 29th October 2015, 03:57 PM
DJS DJS is offline
The runners are on either end on the door and the glass is adjusted with the inner door panel off. I wouldn't use white grease, your better off with silicon spray.
