Old 28th October 2015, 07:08 AM
mannyo mannyo is offline
No leak, thankfully. And it's more the fact that they spray all over the windscreen in addition to using tons of fluid that annoys me.
Mine do work well, but the aim is such only a small splash seems to get onto the bonnet. Apart from the motors running, you'd be hard to tell if anything actually came out.
I went through a phase of going through litres of screen wash, turns out I had a leak which was not really noticeable as it drips onto the engine undertray. Eventually the leak became catastrophic and they stopped working, and failed the MOT. Cause was a split joint, which once replaced all is good once more and hardly any washer fluid is used.
The D3 has an enlarged washer bottle to allow for the headlight washers, so it should last ages.
Manny
Past
Old 28th October 2015, 03:43 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Does it not work the same as it does on the D2? (Short pull, windscreen washers only .... long pull windscreen and headlights). I just use a series of shorter pulls if I don't want to activate the headlight washers.
Give that man a medal
Didn't know about this. Thanks Mark.
2007 Mini Cooper S R56
Old 29th October 2015, 08:11 AM
Witchfinder's Avatar
Witchfinder Witchfinder is offline
I have a leak somewhere, I'm convinced. Added 2 litres to the reservoir a week ago and it's already complaining about being low.
Rob
2013 Audi A7 BiTDi, with Tech Pack High.
2007 Audi S8, with Rear Seat Entertainment, Quad Zone Climate, DAB/DVB and electric blinds. ** sold **
