Old 1st November 2015, 09:12 PM
No its not
Have a look at the options
There is also an option that combines both.
But, as described in post #1 this is Lane Assist, i.e. warning lights that there is something in your blind spot.
Old 2nd November 2015, 09:25 AM
I guess there are marketing terms, sales terms, technical terms and variations in language.
In the UK, as Guy says, the 'feature' that uses lights on the inside of the door mirrors to warn you of traffic in your blind spot, on the side of you is called 'Side assist'.
I guess at a stretch you could argue that when you indicate, 'to change lane' if there is something in the blind spot, the light flashes brightly to warn you. If this is what folks want to believe is a 'lane change assist' feature then so be it.
None of this changes the fact that really, if you're a half decent driver and check your blind spot and mirrors before performing a manoeuvre, then really its a very pointless, verging on annoying 'feature'. Its one of those I would quite literally only have to have to fill a blank on the dash and would/did/do never use
Old 2nd November 2015, 09:26 AM
neeldub neeldub is offline
What settings can you change under Audi Side Assist?
Previously:
2010 Audi A8 4E Quattro Sport TDI Oyster Grey
Currently:
2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey
Old 2nd November 2015, 09:28 AM
Sorry, I should also say each to their own, and regardless of what its called, if you want it, crack on. No one has done it to my knowledge, but probably more through a cost vs benefit than a technical limitation....
Old 2nd November 2015, 08:23 PM
Burnzybubbles's Avatar
What about if you had a freak accident when out, from doing an impression of a chicken and hurt your neck so badly that on the way home you couldn't check your blind spot?
Old 2nd November 2015, 10:04 PM
Talking from experience there mate?
Old 3rd November 2015, 08:45 AM
New law coming up:-
Do not drive after a funky chicken
Old 3rd November 2015, 10:26 AM
I Have actually retro fit this for a Customer it involved The dashboard insert with button, the wiring loom, the sensors that go in the rear bumper, and the mirrors housings and internals,
As for what can be adjusted ... Nothing other than the brightness of the light
As Ian said .. it is a tad gimmicky however having said that late at night when your driving with lots of traffic behind you the auto dimming mirrors on the face lift are far more intense than the Pre face lift they are almost Blue they are so dark that it did actually assist me a couple of times when ive been tired and got complacent after a long drive
If i didn't have it as standard its not something Id rush out to Buy ...
Old 5th November 2015, 10:38 PM
Hey do you happen to remember which control modules did you have to code to enable the system? thanks
Previously:
Currently:
