Old 8th December 2015, 04:39 PM
If I follow that chart correctly you subtract 1048576 from your existing code, I think
Matt
Old 26th December 2015, 12:26 PM
g-black g-black is offline
My rear window heater keeps blowing the 10a fuse. It'll work once, then it blows and won't work again. But when it does work it seems to last longer than 2 minutes as stated here? I think it's a heat insulting screen as it had the blue tint off it. Cars a w12 too if that makes any difference.
Old 26th December 2015, 12:50 PM
Is 10 amp rating what the book says ....sounds a bit light to me , usually with heated screen you would get the heated mirrors running as well , not sure if the mirrors on the same fuse , normally heated screens around 20 amp fuse rating . Could be a special element for low consumption though I suppose .
Old 26th December 2015, 12:56 PM
Here's a thought Architex ..... do you have the air con on in the car ?
Try turning it off and see if rear screen 'on time ' goes any longer
Old 26th December 2015, 05:59 PM
There was a factory 10amp fuse in it (same as the others). Could always have been replaced at the dealers I suppose. I did think it was maybe a little low tolerance but didn't want to risk putting a higher one in incase I would wreck something else.
Old 26th December 2015, 07:28 PM
10A is tiny. Should be 40A fuse in the relay and fuse carrier right hand side in luggage compartment.
Matt
Old 26th December 2015, 08:01 PM
Thanks I'll try that and report back
Old 28th December 2015, 09:41 AM
Cheers Matt. I'll try that and see how it goes!
Old 28th December 2015, 08:26 PM
Just to add to this , tried my rear screen today and it stays on for approx 3 minutes , in that time it has cleared it pretty well .
Old 15th January 2016, 12:41 PM
christer christer is offline
**UPDATE** yep there it is on my option list 4GP - Heat Insulating Glass LOL
I am quite new to this site, but was wondering whether there is an option list somewhere as I have been unable to find one...?
Thanks
Christer
