Old 8th January 2016, 06:05 AM
goldsax goldsax is offline
Default 2001 4.2 ..brake which ones?
i am looking at pagid front and rear pads from ECP the front being the 8 pad set. i presume pad selection is not difficult…
but which discs do i need. as there seems to be 2 sizes ..
i am running standard the 17inch alloy
many thanks
raj
Old 8th January 2016, 06:29 AM
IIRC the Quattro Sport has different brake setup to the non sport version, but cannot say what goes with what.
Old 8th January 2016, 08:35 AM
Well, 345mm discs are for S8 Brembos.
Old 8th January 2016, 09:59 AM
Which PR code do you have out of:
1LJ
1LX
1ZL
As that will determine which parts you need (this is often quoted when you look at the detailed info on the parts offered by ECP)
Adrian
Old 8th January 2016, 01:52 PM
323x30 for the facelift D2 with 4-pad calipers
Pre-facelift had 314mm for non-sport and FWD versions.
Old 8th January 2016, 08:59 PM
would that be 323 x 30 front and rear?
many thanks for the guidance.
raj
Old 9th January 2016, 06:47 AM
Rear is a lot smaller, read here.
http://forum.a8parts.co.uk/showthread.php?t=7739
Old 9th January 2016, 11:22 AM
I find the Brembo site v useful and it appears to show all models/variants and gives the make and size etc of the discs/pads. See link below:
http://www.bremboaftermarket.com/En/...ueBrand=Brembo
