Old 26th January 2016, 01:11 PM
Does the ride height look ok ?? if yes try this .........
Do a hard battery reset ..... remove earth battery lead off battery and cross it over to the positive for 30 seconds or so , this will discharge all capacitors and 'keep alive ' memory functions .
Just taking off a battery lead on modern cars is not a full re boot so that why hard battery reset nessasary nowadays ....... fixes all kinds of issues on Range rovers i can tell you !!
Reconnect battery ....you will have to reset windows and any other learned type functions , put car in dynamic and have a good drive round in it ....vary your speed .... excelerate /de celerate , the ecm should hopefully start to relearn the firmest road map , then try in comfort see if any better .
If this does not fix it i really dont know where to go ???
Old 3rd April 2023, 12:27 PM
Versace Versace is offline
Would it be possible to "tune" the Suspension computer to send more amps to the struts to be softer?
S8 D3 FL II.
Porsche Cayenne 958 Turbo
BMW E83 X3 3.0d M-Sport
