Old 5th March 2016, 07:54 PM
Lee S Lee S is offline
I use RSAP on my MY2010 A8 and a Samsung Galaxy Note (the original one).It was ropey to say the least so I downloaded an RSAP app from Play (and it was about 8 quid) and it works seamlessly now. Apparently the Samsung RSAP stack is crap. Not sure if they changed it from Jellybean onwards though.
Lee
2017 Nissan Leaf Tekna
Old 5th March 2016, 09:02 PM
A8P's Avatar
A8P A8P is offline
Thumbs up
Ok thanks guys, I don't have the connection in the center of my car for a cradle even though Audi said I should have based on spec when I gave them the Reg number. But thanks for offer richardracer.
I saw that app for £7.50 on play store and will give it a go. Is it just a download and go type app or do I need to do anything to make it work?
Failing this I will speak to Samsung about it, maybe they can shed some light on it. Either way if there is a solution I'll update post on here.
Old 5th March 2016, 09:14 PM
RSAP works fine on my Galaxy S5, so suspect it's not the phone.
Old 5th March 2016, 10:36 PM
Ahh there you go then. It's my crappy old Note. But if you do need the app I think you need the phone rooted too.
Lee
Old 6th March 2016, 12:04 PM
A8P's Avatar
A8P A8P is offline
So I rooted phone. Installed rsap app for £7.50 and it still just logs in and out. so frustrating. All I can do now is wait till next week when I do the mmi update to 5570.
This has a Bluetooth update on it. Maybe just maybe.
Old 6th March 2016, 11:03 PM
Hmmm...My car has 3G MMI, so completely different. Sorry I can't be of any more help.
Lee
Old 7th March 2016, 09:07 AM
2008 is a bit borderline for it working easily.
You also have to have the full phone prep with cradle. This means your car has an external aerial, which is required for phone prep.
Or, ironically, you need the really old setup with the fixed handset.
Both of these have all the wiring to support rSap, which needs an external aerial to stand any chance of working.
Then its onto whether your Bluetooth module is up to the job.
Around 2008 the rSap support came.
I have spent many frustrating hours trying to get stuff to work.
Samsungs are generally very good. 2008/2009 Audis are bad. Even my 2010 RS6 needed a Bluetooth firmware update to bring it into life.
2010+ Audis with 3G plus work just out of the box, including Bluetooth audio and everything.....
When its working though, rSap is bloody brilliant.....
Old 7th March 2016, 10:54 AM
Agreed. rSAP is ace. Especially coupled with things like Tasker and Cameralert on Android. It's all so seamless.
Lee
