Old 27th March 2016, 11:43 AM
tgm147 tgm147 is offline
Default Which module remembers the date and time?
Because the car keeps forgetting it! It has been fine for a few weeks but has now got back into the habit of forgetting the date and time when parked up overnight. I'm going to scan it with vagcom today, see if that throws any light on the situation.
Old 27th March 2016, 03:46 PM
There is/was a software bug in the instrument cluster causing this.
Some years needed a coding change, some a software update.
It especially happens if the headlight switch in not in 0 or auto when the ignition is turned off (ie headlights or sidelights manually on)
I think it also happened when the indicator was left on (one side parking lights).
Old 27th March 2016, 06:11 PM
You legend. When it was parked up, I switched the ignition off by the button and locked the wheel with the stop button so it was all off, but I'd left the headlights on. It doesn't have auto lights.
I'll set the clock again and test it.
Thanks for your help!
Old 28th March 2016, 08:52 PM
TGM147; If you have VCDS, I'd be interested in seeing what hardware and software versions it says for your ECU 17 - Instruments.
My 2005 A8 has lost the time numerous times over the years and its log looks like this:
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 F HW: 4E0 920 950 F
Component: KOMBIINSTR. VDO H49 0200
Revision: D03 Serial number: AUDID3DN000886
Coding: 0000418
Shop #: WSC 00028 210 01865
Snapdragon - have you any references as to which versions needed what to fix this please? [I've already got the 0000xx8 coding that the 2005 cars need].
Regards - Julian
Old 29th March 2016, 05:25 PM
Coding: 0000418
Regards - Julian
I do - I'm going out tonight but I'll plug it in tomorrow and get the details for you. I'm going to try and ring Audi too, basically say to them if I book the car in, can you do any software updates available to any modules in the car and see what they say.
Old 29th March 2016, 07:09 PM
Sorry, I just read online somewhere, and most of it has faded away
Old 7th April 2016, 08:03 PM
Coding: 0000418
Regards - Julian
Apologies for the late reply on this, but our details appear to be identical.
Same revision and HW/SW numbers!
Old 7th April 2016, 08:17 PM
Component: KOMBIINSTR. VDO H47 0200
Revision: D02 Serial number: AUDID3D6000058
Coding: 0000408
Shop #: WSC 00468 210 67755
VCID: 27587CDA96F6351
Heres mine
i did the coding which should have fixed it, but didnt, Still goes back to 2004 if i leave the lights on , ignition off and open the door, not always but every now and again
Old 7th April 2016, 09:41 PM
47p2's Avatar
47p2 47p2 is offline
Here's mine, no problems with time or date
Part No SW: 4E0 910 950 P HW: 4E0 920 950 P
Component: KOMBIINSTR. VDO H71 0400
Revision: D02 Serial number: AUDID3E6000248
Coding: 0000413
Shop #: WSC 00759 210 91870
VCID: 3163351AA8327BB
No fault code found.
Nite Blue 3.0L SE Quattro
