Old 31st March 2016, 11:51 PM
Lee S Lee S is offline
Wow.. Haven't seen a new All-Road before...What have Audi done to them ?!?! It looks just like a normal A6 Avant to me !! Stick some plastic "ally" bits on the front,back and side and that means it can go off-road and green-laning?? At least the older model looked as though it could handle "All Roads" and not just the speed bumps at Tescos...
Lee
2017 Nissan Leaf Tekna
Old 1st April 2016, 08:19 AM
Having owned a launch model in 2000 and having driven this one for a couple of months I can confirm what they have done is massively improve it!
It still has the air suspension, but rather than being a test mule for what became the D3 A8 and some what shonky as a result it is well developed and on the "allroad raised" setting has more ground clearance then the original one, which if I remember correctly was boasted as the same as a landrover!
I doubt you'd go green laning or properly off road in either, but ideal for speed bumps and potholes
Old 1st April 2016, 09:11 AM
3.7 slp 3.7 slp is offline
Yep we have a lot of speed humps and pothole in Leicester it always felt as they where slowly killing the A8
Old 1st April 2016, 09:52 AM
Check the build sticker, should confirm power or at least engine code.
Check here for detail - http://forum.a8parts.co.uk/showthread.php?t=37
218, 245 or 272 PS versions of the 3.0 TDI, which equates to 160, 180 or 200 KW I think?
Great thanks for that had a look and its the 245bph with 500lb
that's nice ...and with a remap should be very good...
would anyone have any where to recomemed for remapping around the mildlands .
Old 1st April 2016, 03:54 PM
Shark Performance would be a good shout.. Not sure if they're still doing the 25% off at the minute too.
Old 1st April 2016, 07:34 PM
Great will give them a call
