Old 11th April 2016, 10:35 PM
H-M3 H-M3 is offline
Default claim as stolen or fix it!
right now I have your attention. lol. With the help of my great friend Marcin I managed to get a full fault codes before and after reset on my 8. Can you lovely folks break this down to me in Noob term so I can see what needs urgent attention and what I can leave for time being.Log-H-M3 1ST SCAN-WAUZZZ4E36N015057-189800km-117936mi 1.txt
Log-H-M3 AFTER CLEARING FAULTS-WAUZZZ4E36N015057-189800km-117936.txt
hope this works....?????
Old 11th April 2016, 10:36 PM
sorry if anyone would be kind enough to edit this so it can be viewed on the actual page?
ta
Old 11th April 2016, 11:13 PM
47p2's Avatar
47p2 47p2 is offline
Saturday,09,April,2016,14:34:37:36862
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 15.7.4.1
Data version: 20160216
www.Ross-Tech.com
VIN: WAUZZZ4E36N015057 License Plate: H-M3 AFTER CLEARING FAULTS
Mileage: 189800km-117936mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 18 19 1E 25 28 34 36
37 38 42 46 47 4F 52 53 55 56 57 61 62 67 72 76 77
VIN: WAUZZZ4E36N015057 Mileage: 189800km-117936miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E1 910 409 A HW: 4E1 907 409
Component: 4.2L V8TDI G000AGM™0070
Revision: --H01--- Serial number: AUX3Z0E9377335
Coding: 0011773
Shop #: WSC 00618 210 91869
VCID: 224B051DFD400F2E48-8076
1 Fault Found:
005663 - Glowplug for Cylinder 6 (Q15)
P161F - 001 - Open Circuit
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 188030 km
Time Indication: 0
Date: 2016.02.07
Time: 14:48:40
Freeze Frame:
RPM: 630 /min
Torque: 132.6 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 13.83 V
Duty Cycle: 24.9 %
Temperature: 31.5∞C
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 P HW: 09E 927 156 B
Component: AG6 09E 4,2lTDI RdW 0030
Revision: --H01--- Serial number: 0070253
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 306FFF55A3ACADBECE-8064
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0007557
Shop #: WSC 02313 000 00000
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H08 0160
Revision: 01604808 Serial number: AUX3Z0E9377335
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: 58BF67F5EB9C95FE66-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
4 Faults Found:
00190 - Driver's Door Handle Touch Sensor (G415)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 14
Reset counter: 58
Mileage: 188000 km
Time Indication: 0
Date: 2016.02.06
Time: 18:36:58
00955 - Key 1
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 9
Reset counter: 80
Mileage: 188016 km
Time Indication: 0
Date: 2016.02.07
Time: 14:48:08
00668 - Supply Voltage Terminal 30
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 71
Mileage: 188352 km
Time Indication: 0
Date: 2016.02.24
Time: 18:06:26
01176 - Key
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 255
Mileage: 188544 km
Time Indication: 0
Date: 2016.03.05
Time: 19:04:00
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063840
VCID: 24470305E754011E3A-8070
1 Fault Found:
01964 - Control Module for Seat & Steering Column Memory (J136)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 2
Reset counter: 87
Mileage: 189344 km
Time Indication: 0
Date: 2016.03.28
Time: 13:06:53
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 E HW: 4E0 035 729 A
Component: Interfacebox H43 5150
Revision: 00000000 Serial number: 300KR057560990
Coding: 0000002
VCID: 2E53E12DB998BB4EDC-807A
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Subsystem 2 - Serial number: 00000000030612
Subsystem 3 - Serial number: 0106.02.070000000100010076ˇ
Subsystem 4 - Serial number: 010076ˇ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000080247
Coding: 1136721
VCID: 1C373BE5DF2439DE82-8048
2 Faults Found:
00066 - Rear Right Footwell Heater (Z43)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 100
Mileage: 170922 km
Time Indication: 0
Date: 2014.10.12
Time: 22:47:25
Freeze Frame:
Voltage: 14.00 V
00065 - Rear Left Footwell Heater (Z42)
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Reset counter: 61
Mileage: 142775 km
Time Indication: 0
Date: 2013.03.28
Time: 04:14:06
Freeze Frame:
Voltage: 14.40 V
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Component: ILM Fahrer H13 0210
Coding: 0143121
VCID: 3169FA51A8A6A4B6C1-8064
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H50 0420
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 02313
2 Faults Found:
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 20
Reset counter: 70
Mileage: 186069 km
Time Indication: 0
Date: 2015.10.21
Time: 19:55:15
00908 - Control Module for Wiper Motor
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 71
Mileage: 188665 km
Time Indication: 0
Date: 2016.03.11
Time: 19:38:26
Address 11: Engine II Labels: Redir Fail!
Component: 4.2L V8TDI G000AGS™0070
Coding: 0011773
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 D HW: 4E0 959 655 H
Component: Airbag 9.41 H12 3610
Revision: 91H12360 Serial number: 0037P0009AY2
Coding: 0431707
VCID: 275D14099662EA061F-8072
Subsystem 1 - Serial number: 63328RB400C4BDE3Z
Subsystem 2 - Serial number: 63428RB400C4BD1DX
Subsystem 3 - Serial number: 63528RB400C4BE0F-
Subsystem 4 - Serial number: 63628RB400C4BCED4
Subsystem 5 - Serial number: 63729RB400B6A080I
Subsystem 6 - Serial number: 63829RB400BE574C.
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenks‰ulenmodul H13 0040
Coding: 0112141
VCID: 65C15E01ACEE3816ED-8030
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 P HW: 4E0 920 950 P
Component: KOMBIINSTR. VDO H71 0400
Revision: D02 Serial number: AUDID3EN000445
Coding: 0000413
Shop #: WSC 12345 001 136936
Coding: 0000413
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 E
Component: Heizgeraet H07 0110
Revision: 0000000C Serial number: 00000009006406
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 1A3B3DFDD51047EE90-804E
2 Faults Found:
00664 - Fuel gauge
02072 - Control Module for Energy Management (J644)
Address 19: CAN Gateway Labels: 4E0-910-468.clb
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H11 0090
Revision: 11 Serial number: 2000305B098159
Coding: FCFEFFDE2B7504
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE8014054
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0412672
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 58
Mileage: 188000 km
Time Indication: 0
Date: 2016.02.06
Time: 18:36:58
00955 - Key 1
Freeze Frame:
Fault Priority: 4
Fault Frequency: 9
Reset counter: 80
Mileage: 188016 km
Time Indication: 0
Date: 2016.02.07
Time: 14:48:08
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 71
Mileage: 188352 km
Time Indication: 0
Date: 2016.02.24
Time: 18:06:26
01176 - Key
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 255
Mileage: 188544 km
Time Indication: 0
Date: 2016.03.05
Time: 19:04:00
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 A
Component: KLIMA-STG. FOND 015 0220
Revision: 00000018 Serial number: 00000000034090
Coding: 0000000
VCID: 61C94A11B8C6543611-8034
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
Shop #: WSC 00613 210 88222
VCID: 2A5BED3D8570D76E00-807E
2 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 100
Mileage: 188446 km
Time Indication: 0
Date: 2016.03.01
Time: 20:11:47
01398 - Signal Conductor for Central Locking; Doors Open
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 82
Mileage: 188692 km
Time Indication: 0
Date: 2016.03.13
Time: 23:12:31
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4063850
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
Component: MNS ECE H46 1060
Revision: 00000000 Serial number: 364K/057506849
VCID: 3B75D8797AEA5EE66B-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000528500018
Coding: 0035984
VCID: 1D3136E1C43E30D675-8048
1 Fault Found:
00207 - Humidity Sensor Heater (N340)
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 0
Fault Frequency: 15
Reset counter: 102
Mileage: 187972 km
Time Indication: 0
Date: 2016.02.06
Time: 17:52:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
Component: T¸rsteuer.FS BRM003 0100
Coding: 0032622
VCID: 204F0F15F34C1D3E5E-8074
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 98
Mileage: 189696 km
Time Indication: 0
Date: 2016.04.05
Time: 13:35:48
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040511080555
Coding: 0004861
VCID: 285F17359B7CE57E16-807C
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Component: NGS keine Antwort
2 Faults Found:
00892 - Switch for Trunk Closing Cylinder (F248)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 23
Reset counter: 87
Mileage: 188030 km
Time Indication: 0
Date: 2016.02.07
Time: 17:14:50
02167 - Control Module for Tilt-Sensing Alarm (J529)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Reset counter: 62
Mileage: 153604 km
Time Indication: 0
Date: 2013.12.19
Time: 21:10:44
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
Component: DSP-High D3 H02 0120
Revision: PROD_01 Serial number: 00000000200618
Coding: 0000021
VCID: 2C57EB258F84C95EF2-8078
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000073177
Coding: 0010101
VCID: 1E3331EDC9382BCE6C-804A
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
Component: T¸rsteuer.BF BRM003 0100
Coding: 0032622
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0001031
Shop #: WSC 00654 210 60455
VCID: 1F4D0CE9CE3222C667-804A
1 Fault Found:
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 239
Mileage: 187928 km
Time Indication: 0
Date: 2016.02.04
Time: 16:05:13
Freeze Frame:
Voltage: 12.53 V
Count: 61
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000006
VCID: 3D71D66164FE50D655-8068
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 304KK057611415
Coding: 0000001
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Reset counter: 102
Mileage: 0 km
Time Indication: 0
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 G HW: 4E0 919 146 C
Component: TV analog TUNER H14 0300
Revision: 00000072 Serial number: 00000000021917
Coding: 0000003
VCID: 25411E01EC6EF8162D-8070
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000005041
Shop #: WSC 00947 210 62103
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 1511070713
Coding: 344530393135313035412056413031353131303730373133
Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: T¸rsteuer.HL BRM003 0100
Coding: 0032622
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0630
Revision: 00000000 Serial number: 00000511090356
Shop #: WSC 12336 024 394758
VCID: 3663C94D41C8838E94-8062
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: T¸rsteuer.HR BRM003 0100
Coding: 0032622
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0030
Revision: 00H12000 Serial number: 08720528502256
Coding: 0201108
VCID: 23450019E25A062643-8076
1 Fault Found:
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 3
Reset counter: 63
Mileage: 187972 km
Time Indication: 0
Date: 2016.02.06
Time: 17:50:58
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 F HW: 4E0 862 333 C
Component: TELEFONMODUL EU 0770
Revision: 00000007 Serial number: T2AUDX0706J1VP
Coding: 0000005
End-------------------------(Elapsed Time: 03:35)--------------------------
Nite Blue 3.0L SE Quattro
Old 12th April 2016, 07:07 AM
Burnzybubbles's Avatar
Delete all the codes now you have a copy saved and see what comes back, a couple of codes are dated 2013 so it hasn't been read and cleared in a while.
Something happened on the 6th Feb this year as quite a few codes are dated then, I wouldn't worry to much yet till they have been cleared and you drive it round for a week or two and see what comes back
Old 13th April 2016, 09:28 PM
jza8's Avatar
jza8 jza8 is offline
I bet most of the codes will clear and not come back. Maybe the ignition was on with battery off, unplugged a module with battery connected etc.
2010 Audi A8 4.2 TDI
Old 14th April 2016, 01:27 AM
Default codes
cheers guys but I have only had the car for few months so don't know past diagnostic history. I am sure marcin did reset it as the logs are prior and after?
Old 23rd April 2016, 01:07 PM
... I am sure marcin did reset it as the logs are prior and after?
Very strange
Marcin knows his way around A8s but the second log is identical to the first [except time of run and odd bug where ECU 17 repeats in second log]. I've never seen a VCDS 'DTC Clear' where none of the DTCs seems to have been cleared.
Julian
Old 24th April 2016, 12:12 AM
Originally Posted by JulianHicks View Post
Very strange
Julian
In his defence he was in a rush as he was doing other things whilst toying with my car. Top bloke
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 24th April 2016, 07:15 AM
sometimes using the remove all dtc's doesnt get rid of them all, ussually some though. you then need to go in to each module in turn and delete them and see if they come back
Old 24th April 2016, 07:18 AM
+1 on what he said ^^^^ Often the case!
