Old 13th June 2016, 08:57 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Default ABS 00003 control module 014 defective...
Was just resetting the tourist solution after two weeks away in the D3. While I had the laptop out I did a scan and had a few errors of no concern, bar this one
03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 J HW: 4E0 614 517 CP
Component: ESP 5.7 allrad H50 0540
Coding: 0008357
Shop #: WSC 02313 000 00000
VCID: 2A511C7185E4089
1 Fault Found:
00003 - Control Module
014 - Defective
I have no warning lights on the dash or when previously using the 'check' button. (Only found out about that feature watching my 4 yr old son press every button on the car). The ABS seems to work well. We had to avoid a Merc entering our lane at speed in the wet, to avoid a car that stopped in front of it on the toll roads in France while away. The ABS and ESP seemed to do their jobs immensely.
Anyone have any experience of this fault?
2007 Mini Cooper S R56
Old 14th June 2016, 08:10 AM
Hi John,
Was there a date logged with the fault? Can you clear the fault memory? Have you gone through the output tests?
Try the above and let us know the results.
Matt
Old 14th June 2016, 08:37 AM
Johnmed's Avatar
Hi Matt.
I didn't have the opportunity yesterday to do that, but will try to today and update.
Thanks, John.
Old 14th June 2016, 12:49 PM
Johnmed's Avatar
Hi again. When cleared the fault returns. I hadn't run the output tests, but gave it a bash and the EPB light, headlight range and brake lights flashed on the dash for a bit. Then the control module became unreachable. And VCDS crashed. No dates logged with the code. Seems the module is goosed. Switched the car off and repeatedly cleared the codes like I've read to on Ross Tech's site. All dash warning lights have disappeared.
All works perfectly. Bit odd.
Old 14th June 2016, 03:58 PM
Running the VCDS Output tests causes this on the D3. Rosstech give a procedure to clear it on their site but it didn't work for anyone on another site's thread. I contacted them and they said unplug the connector from the ABS hydraulic unit overnight. To be honest I can't be bothered due to risk of breaking a clip or something.
Old 14th June 2016, 04:49 PM
Johnmed's Avatar
Oh that's interesting. Thank you for telling me. I didn't know.
Old 14th June 2016, 05:34 PM
I have something like it (times 5)
Does this mean that I will have to unplug and wait five nights?
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 M
Component: ESP 5.7 allrad H44 0500
Coding: 0008357
Shop #: WSC 00196 000 00000
VCID: 224BC6BDFD2A9C2E60-8076
5 Faults Found:
014 - Defective - Intermittent
014 - Defective
Old 14th June 2016, 05:53 PM
Johnmed's Avatar
Coding: 0008357
5 Faults Found:
014 - Defective
Ha. Oooh. Yours looks MUCH worse than mine Ray.
Old 14th June 2016, 06:26 PM
I only wanted to let you know that there is always someone worse of than yourself
Apart from that the brakes seem to work OK
In fact management is quite happy driving the 8.
Old 14th June 2016, 08:43 PM
Johnmed's Avatar
I feel at least 5 times better off than you mate
