Old 23rd July 2016, 06:54 AM
Dxthomas Dxthomas is offline
Default Centre Prop & Oil Seal
Not exactly the news I was hoping for...
Car has been in for a full service, and they have found:
1) Centre Prop bearing is worn - causing an annoying whirring noise in the cabin
2) Suspected oil leak from the rear engine seal - engine out job to fix
Damm!
Present
2017 Golf R Estate
2007 Volvo XC90 D5 SE Sport
Past
2006 D3 Audi A8 4.2 tdi LWB
Solar Sunroof, auxiliary heater, DAB, TV, ventilated front seats, heated front & rear seats, AMI, ACC, power boot close
Location - Exeter, Devon
Old 30th July 2016, 06:33 AM
Turbo Tony's Avatar
Ouch. As someone also facing a big bill for repairs, I feel your pain and wish you the best of luck fixing it.
Storytellers Villa Orlando
2008 Audi S8
Old 30th July 2016, 07:02 AM
47p2's Avatar
47p2 47p2 is online now
What's caused the rear oil seal to fail?
Usually caused by either wear (high mileage) or overfilling the sump with too much oil which puts a lot of extra pressure on the seal causing it to fail
Nite Blue 3.0L SE Quattro
Old 30th July 2016, 08:12 AM
Code:
Mine seems to be doing this. How did you diagnose?
I can't tell where the noise is coming from as when I turn my head.
It sounds like some metal being gently turned on a lathe or almost like a hosepipe running but not as loud.
I will try jacking up and spinning the wheels today and hope it is not a prop bearing.
