Old 4th October 2016, 12:53 PM
MatthewH MatthewH is offline
Hi
The pipe between the intake manifold and MAF is sealed and tight. I've checked it for leaks in the past as I thought this may have been the problem.
I've also checked the EVAP hoses (unplugged N80 valve eletrical connector to keep it closed, and I had already replaced the hose between N80 and intake manifold prior to this to rule out any leaks). This doesn't seem to change anything.
I've read some more values this morning after the car had done a short drive:
640 RPM:
- MAF => 4.9 g/s
- Injection timing => 2.46ms
2000 RPM:
- MAF => 12.8 g/s
I'll try to get some logging done while driving.
Thanks
Old 4th October 2016, 06:57 PM
I've just done a quick log while driving. Not the best test data but it's quite hard to get through the rev range on public roads!
I logged the following fields:
- RPM
- MAF g/s
- Fuel Consumption - Signal (not sure what this is)
- Fuel Consumption - Equivalent (not sure what this is)
- Timing Retardation - Cylinder 1
- Timing Retardation - Cylinder 8
- Lambda Control - Bank 1 Sensor 1
- Sensor Voltage - Bank 1 Sensor 1
- Lambda Control - Bank 2 Sensor 1
- Sensor Voltage - Bank 2 Sensor 1
- Injector Timing ms
Code:
1      October                  23:36:03:40973               Data version: 20130910
ADVMB  4.2L V8/5V      G   0040
       G001                     G003                         G009                      G009                          G020                            G021                            G033                             G033                             G033                             G033                             G101
TIME   Group 1 - Field 0        Group 3 - Field 1            Group 9 - Field 2         Group 9 - Field 3             Group 20 - Field 0              Group 21 - Field 3              Group 33 - Field 0               Group 33 - Field 1               Group 33 - Field 2               Group 33 - Field 3               Group 101 - Field 2
STAMP  Engine Speed - (G28)     Mass Air Flow - Sensor (G70) Fuel Consumption - Signal Fuel Consumption - Equivalent Timing Retardation - Cylinder 1 Timing Retardation - Cylinder 8 Lambda Control - Bank 1 Sensor 1 Sensor Voltage - Bank 1 Sensor 1 Lambda Control - Bank 2 Sensor 1 Sensor Voltage - Bank 2 Sensor 1 Injection Timing
        /min                     g/s        �KW                             �KW                              %                                V                                %                                V                                ms
0.09   640                      4.67                         53584                     26                            0                               0                               -6.3                             1.52                             -7.8                             1.52                             2.87
0.67   640                      4.56                         53825                     26                            0                               0                               -7                               1.52                             -7                               1.54                             2.87
1.26   640                      4.67                         54074                     26                            0                               0                               -6.3                             1.52                             -7                               1.54                             2.87
1.82   640                      4.64                         54327                     26                            0                               0                               -6.3                             1.54                             -7                               1.54                             2.87
2.42   640                      4.64                         54587                     26                            0                               0                               -6.3                             1.54                             -7                               1.54                             2.87
3.02   640                      4.61                         54857                     26                            0                               0                               -6.3                             1.54                             -7                               1.54                             2.87
3.58   680                      4.56                         55117                     28                            0                               0                               -6.3                             1.54                             -7                               1.54                             2.87
4.16   640                      4.64                         55377                     28                            0                               0                               -6.3                             1.54                             -7                               1.54                             2.87
4.75   640                      4.64                         55647                     28                            0                               0                               -5.5                             1.54                             -6.3                             1.54                             2.87
5.32   640                      4.5                          55903                     28                            0                               0                               -5.5                             1.54                             -6.3                             1.54                             2.87
5.92   640                      4.72                         56161                     28                            0                               0                               -5.5                             1.56                             -5.5                             1.56                             2.87
6.51   640                      4.61                         56421                     28                            0                               0                               -4.7                             1.56                             -5.5                             1.56                             2.87
7.08   640                      4.64                         56681                     28                            0                               0                               -4.7                             1.54                             -4.7                             1.56                             2.87
7.66   640                      4.61                         56951                     28                            0                               0                               -4.7                             1.54                             -4.7                             1.54                             2.87
8.24   640                      4.58                         57221                     28                            0                               0                               -3.9                             1.54                             -4.7                             1.54                             2.87
8.82   680                      4.58                         57481                     28                            0                               0                               -3.9                             1.54                             -4.7                             1.52                             2.87
9.42   640                      4.64                         57741                     28                            0                               0                               -3.9                             1.54                             -4.7                             1.52                             2.87
10.01  640                      4.67                         58001                     28                            0                               0                               -3.9                             1.52                             -4.7                             1.54                             2.87
10.58  640                      4.67                         58261                     28                            0                               0                               -3.9                             1.54                             -4.7                             1.54                             2.87
11.16  640                      4.72                         58531                     28                            0                               0                               -3.9                             1.54                             -4.7                             1.54                             2.87
11.74  640                      4.64                         58797                     28                            0                               0                               -3.9                             1.54                             -4.7                             1.54                             2.87
12.33  640                      5.11                         59072                     28                            0                               0                               -3.1                             1.56                             -4.7                             1.54                             3.28
12.91  560                      6.89                         59390                     28                            0                               0                               -3.1                             1.56                             -3.9                             1.56                             3.69
13.49  560                      5.58                         59715                     28                            0                               0                               -2.3                             1.56                             -3.1                             1.58                             3.69
14.09  560                      5.33                         60037                     28                            0                               0                               -1.6                             1.56                             -1.6                             1.6                              3.69
14.67  560                      5.17                         60345                     28                            0                               0                               -1.6                             1.56                             -0.8                             1.58                             3.69
15.26  560                      5.39                         60655                     34                            0                               0                               -1.6                             1.54                             0                                1.56                             3.69
15.83  600                      5.61                         61003                     34                            0                               0                               -1.6                             1.52                             0                                1.54                             4.1
16.41  600                      5.64                         61335                     34                            0                               0                               -1.6                             1.54                             0                                1.54                             3.69
16.99  560                      5.5                          61657                     34                            0                               0                               -1.6                             1.54                             0                                1.52                             3.69
17.57  560                      5.33                         61993                     36                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.69
18.15  560                      5.33                         62301                     36                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.69
18.73  560                      5.47                         62623                     36                            0                               0                               -2.3                             1.52                             -0.8                             1.52                             3.69
19.34  560                      5.36                         62945                     36                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.69
19.92  560                      5.39                         63267                     34                            0                               0                               -1.6                             1.54                             -0.8                             1.52                             3.69
20.51  560                      5.33                         63587                     34                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.69
21.08  560                      5.33                         63892                     34                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.69
21.66  520                      6.39                         64206                     34                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.69
22.24  600                      5.67                         64563                     34                            0                               0                               -1.6                             1.54                             0                                1.54                             3.69
22.82  600                      5.67                         64885                     34                            0                               0                               -0.8                             1.56                             0                                1.54                             3.69
23.42  560                      5.44                         65221                     34                            0                               0                               -0.8                             1.54                             0                                1.54                             3.69
24.01  560                      5.42                         7                         34                            0                               0                               -0.8                             1.54                             0                                1.54                             3.69
24.58  560                      5.42                         329                       34                            0                               0                               -0.8                             1.52                             0                                1.52                             3.69
25.17  600                      5.58                         651                       36                            0                               0                               -0.8                             1.54                             0                                1.52                             3.69
25.76  600                      5.39                         1001                      36                            0                               0                               -0.8                             1.54                             0                                1.54                             3.69
26.33  600                      5.28                         1328                      36                            0                               0                               -0.8                             1.52                             0                                1.52                             3.69
26.93  560                      5.72                         1650                      36                            0                               0                               -0.8                             1.52                             0                                1.54                             3.69
27.52  560                      5.31                         1972                      36                            0                               0                               -0.8                             1.52                             0                                1.52                             3.69
28.09  560                      4.97                         2269                      36                            0                               0                               -0.8                             1.52                             0                                1.5                              3.69
28.67  560                      5.14                         2568                      36                            0                               0                               -1.6                             1.5                              0                                1.5                              3.28
29.26  560                      5.08                         2867                      36                            0                               0                               -1.6                             1.5                              -0.8                             1.52                             3.28
29.83  560                      4.92                         3179                      32                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.28
30.41  560                      5                            3465                      32                            0                               0                               -1.6                             1.52                             -0.8                             1.5                              3.28
31.02  560                      4.86                         3751                      32                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.28
31.59  560                      5.06                         4050                      32                            0                               0                               -1.6                             1.54                             -0.8                             1.52                             3.28
32.17  560                      5.06                         4349                      32                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.28
32.77  560                      5.08                         4635                      32                            0                               0                               -1.6                             1.54                             -0.8                             1.54                             3.28
33.33  560                      5.06                         4934                      32                            0                               0                               -1.6                             1.52                             -0.8                             1.54                             3.28
33.91  560                      5.03                         5246                      32                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.28
34.5   560                      5.08                         5532                      32                            0                               0                               -1.6                             1.54                             -0.8                             1.52                             3.28
35.07  560                      5.11                         5831                      32                            0                               0                               -1.6                             1.52                             -0.8                             1.54                             3.28
35.67  560                      5                            6117                      32                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.28
36.26  560                      5                            6416                      32                            0                               0                               -1.6                             1.52                             -0.8                             1.52                             3.28
36.83  560                      5                            6702                      32                            0                               0                               -1.6                             1.54                             -0.8                             1.52                             3.28
37.41  560                      5.11                         7001                      32                            0                               0                               -1.6                             1.54                             -0.8                             1.54                             3.28
37.99  560                      5.06                         7313                      32                            0                               0                               -0.8                             1.54                             -0.8                             1.54                             3.28
38.57  560                      5.11                         7599                      32                            0                               0                               -1.6                             1.52                             0                                1.54                             3.28
39.17  560                      5.03                         7898                      32                            0                               0                               -0.8                             1.54                             -0.8                             1.52                             3.28
39.76  560                      5.03                         8184                      32                            0                               0                               -0.8                             1.52                             -0.8                             1.54                             3.28
40.33  560                      5.03                         8483                      32                            0                               0                               -0.8                             1.54                             0                                1.54                             3.28
40.91  560                      4.97                         8782                      32                            0                               0                               -0.8                             1.54                             0                                1.54                             3.28
41.49  560                      5.06                         9081                      32                            0                               0                               -0.8                             1.52                             0                                1.52                             3.28
42.07  560                      5.03                         9380                      32                            0                               0                               -0.8                             1.52                             0                                1.52                             3.28
42.67  560                      5.14                         9666                      32                            0                               0                               -0.8                             1.52                             0                                1.52                             3.28
43.26  560                      5                            9965                      32                            0                               0                               -0.8                             1.54                             0                                1.52                             3.28
43.83  560                      5.03                         10264                     32                            0                               0                               -0.8                             1.52                             0                                1.54                             3.28
44.41  560                      5.03                         10550                     32                            0                               0                               -0.8                             1.52                             0                                1.54                             3.28
44.99  520                      6.03                         10845                     32                            0                               0                               -0.8                             1.54                             0                                1.54                             3.69
45.58  600                      5.5                          11200                     32                            0                               0                               -0.8                             1.54                             0                                1.52                             4.1
46.16  600                      5.72                         11551                     32                            0                               0                               0                                1.54                             0                                1.54                             3.69
46.74  520                      7.78                         11957                     34                            0                               0                               0.8                              1.5                              1.6                              1.54                             5.33
47.34  600                      7.36                         12376                     34                            0                               0                               -2.3                             1.48                             0                                1.52                             4.51
47.92  640                      7.86                         12826                     34                            0                               0                               0.8                              1.6                              1.6                              1.58                             4.51
48.51  760                      8.58                         13368                     34                            0                               0                               3.1                              1.62                             3.1                              1.6                              4.92
49.08  880                      10.58                        13980                     50                            0                               0                               4.7                              1.58                             4.7                              1.58                             4.51
49.66  880                      9.72                         14630                     50                            0                               0                               4.7                              1.56                             5.5                              1.54                             4.51
50.24  1040                     15.75                        15449                     50                            0                               0                               0                                1.58                             0                                1.58                             5.74
50.84  1200                     15.64                        16403                     50                            0                               0                               5.5                              1.58                             5.5                              1.6                              5.33
51.42  1280                     17.17                        17384                     86                            0                               0                               3.1                              1.5                              3.1                              1.5                              5.33
52.01  1360                     15.92                        18417                     86                            0                               0                               2.3                              1.48                             2.3                              1.48                             4.92
52.58  1400                     22.31                        19445                     86                            0                               0                               1.6                              1.46                             2.3                              1.48                             4.92
53.16  1680                     24.28                        20857                     86                            0                               0                               1.6                              1.5                              2.3                              1.5                              5.74
53.74  1760                     28.69                        22481                     130                           0                               0                               0.8                              1.5                              0.8                              1.48                             6.15
54.32  1520                     28.28                        24038                     130                           0                               0                               -1.6                             1.46                             0                                1.48                             6.97
54.92  1720                     32.11                        25947                     130                           0                               0                               -1.6                             1.46                             -0.8                             1.46                             7.38
55.51  1800                     27.28                        27790                     130                           0                               0                               -1.6                             1.52                             -1.6                             1.5                              6.97
56.08  1760                     29.14                        29448                     190                           0                               0                               -0.8                             1.54                             -0.8                             1.52                             6.56
56.66  1840                     34.67                        31309                     190                           0                               0                               -1.6                             1.5                              -1.6                             1.48                             6.97
57.24  1840                     29.78                        33139                     190                           0                               0                               -1.6                             1.5                              -1.6                             1.5                              6.15
57.82  1760                     20.56                        34505                     190                           0                               0                               0.8                              1.54                             0                                1.54                             4.92
58.42  1720                     18                           35564                     172                           0                               0                               1.6                              1.54                             1.6                              1.54                             4.1
59.01  1720                     16.5                         36572                     172                           0                               0                               2.3                              1.5                              1.6                              1.5                              4.1
59.58  1680                     16.39                        37508                     172                           0                               0                               1.6                              1.48                             0.8                              1.48                             3.69
60.15  1640                     16.42                        38475                     172                           0                               0                               1.6                              1.48                             0.8                              1.48                             4.1
60.76  1640                     21.17                        39534                     108                           0                               0                               -0.8                             1.44                             -0.8                             1.46                             4.1
61.32  1760                     24.89                        40950                     108                           0                               0                               0                                1.52                             -0.8                             1.5                              5.74
61.92  1800                     28.83                        42434                     108                           0                               0                               -1.6                             1.48                             -2.3                             1.48                             5.33
62.52  1920                     27.19                        44010                     108                           0                               0                               -1.6                             1.5                              -2.3                             1.52                             5.74
63.08  1560                     23.03                        45453                     162                           0                               0                               -2.3                             1.46                             -1.6                             1.5                              5.74
63.66  1560                     24.67                        46815                     162                           0                               0                               -0.8                             1.54                             0                                1.54                             6.15
64.26  1640                     26.33                        48386                     162                           0                               0                               -0.8                             1.52                             0.8                              1.5                              6.15
64.82  1600                     21.67                        49868                     162                           0                               0                               -1.6                             1.48                             0                                1.48                             6.15
65.42  1320                     16.08                        50860                     162                           0                               0                               0                                1.58                             0                                1.56                             4.51
66.01  1400                     15.89                        51741                     98                            0                               0                               2.3                              1.56                             2.3                              1.58                             4.51
66.58  1400                     16.75                        52661                     98                            0                               0                               2.3                              1.52                             3.1                              1.52                             4.51
67.17  1440                     20.42                        53661                     98                            0                               0                               1.6                              1.46                             2.3                              1.48                             4.51
67.76  1440                     18.58                        54752                     98                            0                               0                               0.8                              1.46                             1.6                              1.48                             4.92
68.33  1480                     19.22                        55847                     72                            0                               0                               -1.6                             1.46                             0                                1.48                             5.33
68.91  1480                     17.83                        56975                     72                            0                               0                               -1.6                             1.52                             -0.8                             1.5                              4.92
69.49  1480                     17.83                        58019                     72                            0                               0                               -1.6                             1.5                              -0.8                             1.5                              4.92
70.07  1520                     16.86                        59050                     72                            0                               0                               -1.6                             1.48                             -0.8                             1.52                             4.51
70.67  1480                     16.08                        59994                     78                            0                               0                               -0.8                             1.52                             0                                1.54                             4.51
71.26  1520                     11.39                        60869                     78                            0                               0                               -0.8                             1.52                             0                                1.52                             4.1
71.83  1440                     10.69                        61536                     78                            0                               0                               1.6                              1.58                             1.6                              1.56                             3.28
72.41  1440                     10.39                        62152                     78                            0                               0                               3.9                              1.58                             3.9                              1.58                             3.28
72.99  1440                     9.86                         62808                     54                            0                               0                               4.7                              1.54                             5.5                              1.56                             3.69
73.57  1400                     9.42                         63418                     54                            0                               0                               4.7                              1.54                             4.7                              1.52                             3.28
74.15  1400                     15.86                        64132                     54                            0                               0                               6.3                              1.54                             6.3                              1.52                             3.69
74.73  1440                     16.22                        65070                     54                            0                               0                               4.7                              1.48                             4.7                              1.48                             4.51
75.34  1440                     16.5                         486                       56                            0                               0                               3.1                              1.48                             3.9                              1.48                             4.51
75.92  1440                     16.47                        1438                      56                            0                               0                               3.9                              1.5                              3.9                              1.5                              4.51
76.51  1440                     16.78                        2390                      56                            0                               0                               3.9                              1.52                             4.7                              1.52                             4.51
77.08  1440                     15.89                        3327                      56                            0                               0                               4.7                              1.54                             5.5                              1.54                             4.51
77.66  1440                     7.53                         4181                      68                            0                               0                               5.5                              1.54                             6.3                              1.54                             4.1
78.24  1360                     10.31                        4781                      68                            0                               0                               7.8                              1.58                             7.8                              1.56                             3.28
78.84  1320                     10.28                        5365                      68                            0                               0                               9.4                              1.56                             9.4                              1.56                             3.28
79.43  1320                     9.75                         5960                      68                            0                               0                               10.2                             1.54                             10.2                             1.54                             3.28
80.02  1280                     9.22                         6532                      44                            0                               0                               10.2                             1.52                             9.4                              1.52                             3.28
80.59  1280                     9.03                         7081                      44                            0                               0                               10.9                             1.54                             10.2                             1.52                             3.28
81.17  1280                     13.97                        7708                      44                            0                               0                               11.7                             1.52                             11.7                             1.54                             3.69
81.76  1320                     13.31                        8504                      44                            0                               0                               9.4                              1.44                             9.4                              1.46                             4.1
82.33  1320                     13.19                        9274                      48                            0                               0                               9.4                              1.48                             8.6                              1.46                             4.1
82.93  1320                     13.39                        10105                     48                            0                               0                               8.6                              1.48                             7.8                              1.48                             4.1
83.52  1320                     15.47                        10927                     48                            0                               0                               8.6                              1.5                              7.8                              1.5                              4.1
84.09  1320                     14.97                        11811                     48                            0                               0                               7.8                              1.5                              7                                1.5                              4.51
84.67  1320                     14.72                        12695                     62                            0                               0                               7                                1.48                             7                                1.48                             4.51
85.26  1320                     13.28                        13595                     62                            0                               0                               6.3                              1.48                             6.3                              1.48                             4.51
85.83  1280                     10.06                        14255                     62                            0                               0                               7                                1.54                             6.3                              1.52                             3.69
86.43  1280                     10.36                        14855                     62                            0                               0                               8.6                              1.54                             7                                1.54                             3.28
87.02  1280                     10.25                        15455                     62                            0                               0                               6.3                              1.52                             10.2                             1.56                             3.28
87.59  1200                     9.42                         16031                     50                            0                               0                               11.7                             1.54                             6.3                              1.54                             3.28
88.17  1200                     9.06                         16595                     50                            0                               0                               0                                1.54                             0                                1.5                              3.28
88.76  1040                     8.06                         17099                     50                            0                               0                               -2.3                             1.54                             3.1                              1.56                             3.28
89.33  840                      6.81                         17484                     50                            0                               0                               3.1                              1.54                             -1.6                             1.52                             3.28
89.92  760                      6.53                         17869                     36                            0                               0                               3.9                              1.56                             -1.6                             1.58                             3.69
90.52  640                      8.36                         18295                     36                            0                               0                               2.3                              1.56                             2.3                              1.56                             4.92
91.08  720                      7.03                         18745                     36                            0                               0                               4.7                              1.54                             -0.8                             1.54                             4.51
91.66  640                      7.11                         19147                     36                            0                               0                               4.7                              1.54                             0                                1.58                             4.1
92.26  680                      7.42                         19595                     30                            0                               0                               0.8                              1.56                             6.3                              1.56                             4.51
92.82  640                      15.61                        20048                     30                            0                               0                               6.3                              1.58                             1.6                              1.56                             4.51
93.42  840                      8.19                         20606                     30                            0                               0                               0.8                              1.48                             4.7                              1.52                             4.92
94.01  800                      7.92                         21096                     30                            0                               0                               1.6                              1.54                             6.3                              1.54                             4.1
94.58  920                      22.14                        21794                     36                            0                               0                               0                                1.48                             0                                1.48                             4.92
95.17  1240                     18.56                        22866                     36                            0                               0                               3.1                              1.6                              5.5                              1.58                             5.74
95.76  1320                     20.5                         23988                     36                            0                               0                               0                                1.4                              5.5                              1.56                             5.74
96.33  1400                     27.72                        25201                     36                            0                               0                               4.7                              1.52                             0                                1.46                             5.74
96.91  1600                     26.81                        26643                     82                            0                               0                               0                                1.56                             5.5                              1.48                             6.15
97.49  1760                     29.53                        28411                     82                            0                               0                               3.1                              1.42                             -0.8                             1.54                             6.97
98.07  1880                     31.94                        30222                     82                            0                               0                               2.3                              1.5                              0                                1.48                             6.56
98.66  2160                     68.81                        32806                     82                            0                               0                               0.8                              1.56                             1.6                              1.56                             8.61
99.27  2240                     72.03                        36614                     162                           0                               0                               0.8                              1.44                             1.6                              1.44                             12.3
99.84  2440                     61.11                        41118                     162                           0                               3                               0                                1.02                             0                                1.08                             13.53
100.42 1800                     10.97                        42308                     162                           0                               0                               2.3                              1.66                             1.6                              1.62                             3.28
101.01 1560                     11.08                        42957                     162                           0                               0                               7.8                              1.56                             7                                1.62                             2.87
101.58 1280                     9.42                         43513                     148                           0                               0                               8.6                              1.56                             3.1                              1.54                             2.87
102.16 1320                     6.22                         44001                     148                           0                               0                               3.9                              1.52                             8.6                              1.54                             2.87
102.77 1080                     15.92                        44378                     148                           0                               0                               4.7                              1.66                             0                                1.64                             2.46
103.34 1320                     9.75                         44870                     148                           0                               0                               2.3                              1.54                             9.4                              1.6                              2.87
103.92 1360                     9.58                         45457                     34                            0                               0                               1.6                              1.52                             8.6                              1.54                             3.28
104.51 1400                     7                            45988                     34                            0                               0                               8.6                              1.56                             3.9                              1.52                             2.87
105.08 1320                     6.94                         46432                     34                            0                               0                               3.9                              1.56                             10.2                             1.58                             2.46
105.66 1280                     9.67                         46897                     34                            0                               0                               7.8                              1.6                              14.8                             1.6                              2.87
106.27 1280                     9.33                         47447                     36                            0                               0                               11.7                             1.54                             8.6                              1.5                              3.28
106.84 1200                     8.89                         47975                     36                            0                               0                               7                                1.5                              12.5                             1.5                              3.28
107.42 1120                     8.42                         48463                     36                            0                               0                               6.3                              1.48                             12.5                             1.48                             3.28
108.01 1000                     7.67                         48955                     36                            0                               0                               9.4                              1.44                             5.5                              1.42                             3.69
108.58 1160                     9.03                         49461                     36                            0                               0                               3.1                              1.44                             8.6                              1.48                             3.28
109.16 960                      7.81                         49949                     36                            0                               0                               7                                1.46                             3.1                              1.4                              3.28
109.74 800                      7.11                         50337                     36                            0                               0                               5.5                              1.42                             0.8                              1.42                             3.28
110.34 720                      6.19                         50714                     36                            0                               0                               0                                1.48                             5.5                              1.48                             3.69
110.93 720                      5.78                         51172                     36                            0                               0                               5.5                              1.5                              0                                1.42                             4.51
111.52 680                      8                            51577                     30                            0                               0                               4.7                              1.48                             -1.6                             1.48                             4.1
112.09 680                      7.17                         51993                     30                            0                               0                               0.8                              1.54                             4.7                              1.54                             4.51
112.67 640                      8.06                         52449                     30                            0                               0                               6.3                              1.56                             0                                1.56                             4.1
113.26 680                      7.83                         52948                     30                            0                               0                               0.8                              1.5                              5.5                              1.56                             4.92
113.83 800                      32.5                         53753                     32                            0                               0                               0                                1.42                             0                                1.42                             6.56
114.43 1600                     30.75                        55495                     32                            0                               0                               2.3                              1.5                              -1.6                             1.5                              8.61
115.02 1800                     34.08                        57469                     32                            0                               0                               -1.6                             1.5                              1.6                              1.42                             7.38
115.59 2040                     37.72                        59591                     32                            0                               0                               -2.3                             1.5                              2.3                              1.58                             7.38
116.17 1720                     32.5                         61524                     130                           0                               0                               2.3                              1.48                             -1.6                             1.52                             7.38
116.76 1920                     48.86                        63985                     130                           0                               0                               -2.3                             1.56                             1.6                              1.44                             9.02
117.33 2120                     49.75                        1212                      130                           0                               0                               -1.6                             1.46                             3.1                              1.56                             9.02
117.91 2240                     51.28                        4198                      130                           0                               0                               1.6                              1.46                             -1.6                             1.44                             9.43
118.52 1960                     55.75                        7051                      192                           0                               0                               0.8                              1.52                             1.6                              1.46                             9.43
119.08 2160                     66.06                        10545                     192                           0                               0                               3.1                              1.46                             -2.3                             1.56                             11.07
119.66 2280                     67.94                        14489                     192                           3                               3                               1.6                              1.46                             -1.6                             1.46                             12.3
120.26 2240                     68.08                        18424                     192                           3                               3                               -2.3                             1.52                             0.8                              1.46                             11.89
120.83 2040                     46.53                        21880                     268                           3                               3                               0                                1.32                             0                                1.34                             11.48
121.41 1640                     10.03                        23013                     268                           0                               0                               2.3                              1.62                             1.6                              1.58                             3.69
121.99 1280                     9.19                         23572                     268                           0                               0                               6.3                              1.62                             5.5                              1.64                             3.28
122.57 1040                     7.31                         24051                     268                           0                               0                               6.3                              1.66                             1.6                              1.64                             3.28
123.17 1000                     8.03                         24500                     62                            0                               0                               7                                1.56                             3.1                              1.6                              3.28
123.76 880                      6.64                         24918                     62                            0                               0                               1.6                              1.54                             7                                1.54                             3.28
124.33 960                      6.69                         25322                     62                            0                               0                               7                                1.56                             2.3                              1.52                             3.28
124.92 840                      6.47                         25715                     62                            0                               0                               3.9                              1.58                             8.6                              1.6                              3.28
125.51 960                      7.83                         26124                     30                            0                               0                               4.7                              1.56                             9.4                              1.58                             3.28
126.08 800                      6.06                         26512                     30                            0                               0                               9.4                              1.52                             4.7                              1.52                             3.28
126.66 680                      15.19                        26867                     30                            0                               0                               3.9                              1.5                              9.4                              1.52                             3.28
127.24 680                      5.94                         27306                     30                            0                               0                               2.3                              1.46                             7.8                              1.42                             4.1
127.82 680                      6.28                         27707                     28                            0                               0                               6.3                              1.46                             1.6                              1.46                             4.1
128.4  640                      9.83                         28104                     28                            0.8                             0.8                             0.8                              1.44                             6.3                              1.5                              4.1
129.01 680                      7.33                         28576                     28                            0.8                             0.8                             3.9                              1.46                             0.8                              1.46                             4.51
129.58 680                      8.03                         28998                     28                            0                               0                               2.3                              1.54                             2.3                              1.5                              4.51
130.16 920                      11.08                        29773                     28                            0                               0                               0                                1.4                              0                                1.34                             6.15
130.74 1200                     17.33                        30635                     38                            0                               0                               4.7                              1.58                             3.9                              1.56                             4.92
131.32 1560                     28.06                        32261                     38                            0                               0                               1.6                              1.5                              -1.6                             1.52                             7.38
131.9  1800                     28.94                        33946                     38                            0                               0                               -2.3                             1.52                             2.3                              1.46                             6.56
132.51 1880                     31.53                        35751                     38                            0                               0                               3.1                              1.48                             -1.6                             1.58                             6.56
133.09 1680                     28.17                        37430                     112                           0                               0                               3.1                              1.56                             -2.3                             1.46                             6.97
133.67 1760                     30.69                        39169                     112                           0                               0                               -2.3                             1.48                             1.6                              1.48                             6.97
134.26 1880                     32.22                        40975                     112                           0                               0                               0.8                              1.42                             -2.3                             1.56                             6.56
134.83 2040                     37.22                        42995                     112                           0                               0                               -3.1                             1.54                             1.6                              1.4                              6.97
135.41 1800                     33.58                        45063                     134                           0                               0                               -2.3                             1.44                             2.3                              1.54                             7.38
135.99 1800                     34.5                         47021                     134                           0                               0                               1.6                              1.44                             -2.3                             1.5                              7.38
136.57 1800                     35.03                        49011                     134                           0                               0                               -2.3                             1.54                             1.6                              1.44                             7.38
137.17 1680                     30.5                         50860                     134                           0                               0                               -3.1                             1.44                             2.3                              1.56                             7.38
137.76 1680                     9.06                         52162                     140                           0                               0                               2.3                              1.62                             -2.3                             1.52                             4.92
138.33 1280                     10.53                        52776                     140                           0                               0                               1.6                              1.62                             7                                1.6                              3.28
138.92 1280                     10.11                        53388                     140                           0                               0                               3.1                              1.58                             8.6                              1.56                             3.28
139.51 1320                     7.58                         53971                     140                           0                               0                               7.8                              1.54                             3.9                              1.48                             3.28
140.08 1200                     6.31                         54376                     46                            0                               0                               3.9                              1.56                             9.4                              1.58                             2.46
140.66 1120                     9.19                         54780                     46                            0                               0                               10.9                             1.66                             5.5                              1.68                             2.46
141.24 1320                     9.67                         55416                     46                            0                               0                               5.5                              1.4                              2.3                              1.42                             3.28
141.82 1320                     10.14                        55993                     46                            0                               0                               1.6                              1.48                             6.3                              1.5                              3.28
142.42 1320                     9.11                         56575                     38                            0                               0                               7                                1.52                             2.3                              1.48                             3.28
143.01 1360                     8.86                         57095                     38                            0                               0                               7.8                              1.52                             2.3                              1.5                              2.87
143.58 1360                     6.89                         57616                     38                            0                               0                               3.1                              1.48                             7.8                              1.52                             2.87
144.16 1240                     6.22                         58008                     38                            0                               0                               8.6                              1.54                             4.7                              1.52                             2.46
144.74 1200                     5.67                         58358                     32                            0                               0                               0                                1.68                             0                                1.62                             2.46
145.32 1320                     6.89                         58722                     32                            0                               0                               0                                2.58                             0                                2.76                             2.05
145.93 1280                     6.44                         59002                     32                            0                               0                               0                                3.32                             0                                3.5                              2.05
146.52 1280                     6.42                         59002                     32                            0                               0                               0                                3.8                              0                                3.96                             0
147.09 1320                     6.64                         59002                     12                            0                               0                               0                                4.2                              0                                3.92                             0
147.67 1280                     6.25                         59002                     12                            0                               0                               0                                4.02                             0                                4.26                             0
148.26 1240                     6.39                         59002                     12                            0                               0                               0                                4.28                             0                                4.08                             0
148.82 1240                     6.19                         59002                     12                            0                               0                               0                                4.32                             0                                4.08                             0
149.41 1240                     6.31                         59002                     0                             0                               0                               0                                4.12                             0                                4.28                             0
150.02 1200                     5.81                         59002                     0                             0                               0                               0                                4.3                              0                                4.12                             0
150.58 1120                     5.19                         59073                     0                             0                               0                               0                                4                                0                                4.1                              0
151.16 1080                     9.42                         59543                     0                             0                               0                               0                                2.34                             0                                2.64                             3.28
151.74 1160                     9.11                         60059                     0                             0                               0                               0                                1.94                             0                                2.12                             3.28
152.32 1160                     9.06                         60606                     20                            0                               0                               0                                1.78                             0                                1.8                              3.28
152.9  1000                     8.39                         61098                     20                            0                               0                               7.8                              1.66                             3.9                              1.68                             3.28
153.51 880                      6.97                         61539                     20                            0                               0                               2.3                              1.54                             7.8                              1.54                             3.69
154.08 760                      5.97                         61911                     20                            0                               0                               5.5                              1.5                              1.6                              1.5                              3.28
154.67 680                      6.89                         62327                     32                            0                               0                               5.5                              1.48                             1.6                              1.52                             4.51
155.26 680                      6.39                         62733                     32                            0                               0                               0                                1.48                             5.5                              1.48                             4.1
155.83 680                      6.44                         63111                     32                            0                               0                               4.7                              1.5                              0.8                              1.48                             3.69
156.41 840                      19.56                        63590                     32                            0                               0                               0                                1.54                             0                                1.5                              3.69
156.99 1440                     35.92                        65194                     34                            0                               0                               0                                1.54                             0                                1.56                             7.79
157.59 1880                     43.31                        2090                      34                            0                               0                               0.8                              1.48                             -0.8                             1.52                             9.02
158.17 2080                     56                           4971                      34                            0                               0                               -1.6                             1.54                             2.3                              1.46                             9.84
158.76 2280                     58.19                        8230                      34                            0                               0                               -0.8                             1.44                             2.3                              1.54                             10.25
159.33 2280                     58.11                        11667                     204                           0                               0                               0.8                              1.48                             -3.1                             1.56                             10.25
159.91 2160                     55.64                        14777                     204                           0                               3                               0.8                              1.56                             0                                1.48                             10.25
160.49 2320                     68.11                        18495                     204                           0                               3                               0                                1.34                             0                                1.36                             11.48
161.08 2080                     8.61                         20952                     204                           0                               0                               0                                1.26                             0                                1.26                             6.56
161.66 1480                     10.75                        21575                     204                           0                               0                               0.8                              1.56                             0                                1.56                             2.87
162.24 1320                     9.64                         22095                     204                           0                               0                               5.5                              1.58                             1.6                              1.6                              2.87
162.84 1320                     9.53                         22615                     204                           0                               0                               7                                1.56                             2.3                              1.56                             2.87
163.42 1280                     6.33                         23043                     204                           0                               0                               0.8                              1.5                              7                                1.56                             2.46
164.01 1040                     7.78                         23418                     34                            0                               0                               7.8                              1.66                             1.6                              1.64                             2.87
164.58 1280                     9.28                         23936                     34                            0                               0                               4.7                              1.48                             1.6                              1.54                             2.87
165.16 1280                     9                            24457                     34                            0                               0                               0.8                              1.5                              7                                1.54                             2.87
165.74 1360                     14.97                        25194                     34                            0                               0                               7.8                              1.52                             3.1                              1.48                             4.51
166.34 1360                     17.67                        26168                     46                            0                               0                               0                                1.58                             3.9                              1.54                             4.92
166.93 1360                     17.67                        27244                     46                            0                               0                               0.8                              1.46                             5.5                              1.56                             5.33
167.52 1320                     7.44                         28223                     46                            0                               0                               4.7                              1.48                             -0.8                             1.38                             5.33
168.09 1280                     9.28                         28833                     46                            0                               0                               2.3                              1.56                             5.5                              1.56                             3.28
168.67 1280                     29.28                        29646                     62                            0                               0                               1.6                              1.26                             1.6                              1.28                             4.1
169.26 1440                     28.42                        31345                     62                            0                               0                               0                                1.5                              0                                1.48                             7.38
169.83 1320                     24.36                        32812                     62                            0                               0                               -1.6                             1.5                              1.6                              1.48                             7.38
170.43 1400                     20.92                        34048                     62                            0                               0                               -0.8                             1.48                             3.9                              1.6                              6.15
171.02 1400                     21.28                        35311                     62                            0                               0                               4.7                              1.58                             0                                1.5                              6.15
171.59 1440                     25.69                        36754                     102                           0                               0                               -1.6                             1.52                             3.1                              1.44                             6.97
172.17 1480                     29.33                        38328                     102                           0                               0                               1.6                              1.42                             -1.6                             1.54                             7.79
172.76 1440                     11.58                        39927                     102                           0                               0                               0                                1.52                             -3.9                             1.38                             7.79
173.33 1400                     10.56                        40635                     102                           0                               0                               0.8                              1.6                              5.5                              1.64                             3.28
173.93 1520                     33.06                        41808                     96                            0                               0                               3.1                              1.42                             -0.8                             1.52                             5.74
174.52 1440                     25.58                        43317                     96                            0                               0                               3.1                              1.52                             -1.6                             1.34                             6.97
175.09 1200                     23.58                        44661                     96                            0                               0                               -0.8                             1.48                             3.9                              1.56                             7.38
175.67 1160                     22.94                        45980                     96                            0                               0                               3.9                              1.42                             -0.8                             1.5                              7.38
176.26 1160                     23.14                        47343                     98                            0                               0                               3.1                              1.54                             -0.8                             1.42                             7.79
176.83 1160                     22.56                        48670                     98                            0                               0                               -1.6                             1.44                             3.9                              1.56                             7.38
177.43 1160                     21.28                        49922                     98                            0                               0                               3.9                              1.52                             -0.8                             1.5                              6.97
178.02 1200                     4.78                         51027                     98                            0                               0                               -3.9                             1.42                             1.6                              1.46                             6.97
178.58 1120                     8.56                         51557                     88                            0                               0                               -1.6                             1.58                             3.9                              1.58                             3.28
179.16 1240                     16.75                        52378                     88                            0                               0                               3.9                              1.56                             -1.6                             1.52                             5.33
179.76 1240                     18.08                        53429                     88                            0                               0                               0                                1.56                             3.9                              1.5                              5.33
180.32 1200                     17.31                        54429                     88                            0                               0                               0                                1.48                             4.7                              1.56                             5.74
180.92 1160                     16.64                        55396                     64                            0                               0                               5.5                              1.58                             0                                1.48                             5.74
181.51 1200                     14.58                        56350                     64                            0                               0                               0.8                              1.48                             6.3                              1.54                             5.33
182.08 1120                     12.17                        57101                     64                            0                               0                               7                                1.56                             2.3                              1.56                             4.51
182.67 1160                     7.94                         57815                     64                            0                               0                               2.3                              1.58                             -2.3                             1.52                             4.51
183.26 1080                     8.08                         58340                     58                            0                               0                               0.8                              1.58                             5.5                              1.6                              3.28
183.83 1080                     7.58                         58819                     58                            0                               0                               5.5                              1.56                             0.8                              1.54                             3.28
184.41 1080                     7.69                         59274                     58                            0                               0                               6.3                              1.56                             1.6                              1.58                             3.28
184.99 1080                     8.03                         59704                     58                            0                               0                               2.3                              1.56                             7.8                              1.6                              2.87
185.57 1160                     12.92                        60409                     36                            0                               0                               0                                1.52                             0                                1.52                             4.51
186.15 1200                     22.5                         61330                     36                            0                               0                               4.7                              1.6                              -1.6                             1.54                             4.51
186.76 1160                     6.11                         62238                     36                            0                               0                               -3.1                             1.48                             2.3                              1.56                             5.74
187.33 1040                     14.56                        62786                     36                            0                               0                               0                                1.6                              0                                1.6                              3.28
187.91 1320                     25.03                        64028                     64                            0                               0                               0                                1.46                             0                                1.46                             7.38
188.49 1200                     23.72                        65485                     64                            0                               0                               -1.6                             1.5                              1.6                              1.56                             7.79
189.08 1120                     21.89                        1280                      64                            0                               3                               2.3                              1.48                             -2.3                             1.5                              7.79
189.66 1120                     11.86                        2395                      64                            0                               3                               -2.3                             1.58                             3.1                              1.54                             6.56
190.24 1200                     14.36                        3242                      88                            0                               3                               0.8                              1.56                             6.3                              1.6                              4.92
190.82 1120                     8.64                         3834                      88                            0                               0                               4.7                              1.62                             0                                1.6                              3.69
191.41 1120                     8.86                         4365                      88                            0                               0                               0.8                              1.52                             7                                1.58                             3.28
191.99 1120                     8.22                         4849                      88                            0                               0                               0.8                              1.56                             7.8                              1.54                             3.28
192.59 1120                     7.67                         5305                      88                            0                               0                               6.3                              1.56                             3.9                              1.52                             2.87
193.17 1120                     7.25                         5735                      36                            0                               0                               2.3                              1.52                             9.4                              1.52                             2.87
193.76 1080                     7.22                         6165                      36                            0                               0                               7                                1.54                             4.7                              1.5                              2.87
194.33 1080                     7.17                         6595                      36                            0                               0                               7.8                              1.54                             4.7                              1.5                              2.87
194.91 1080                     7.19                         7035                      36                            0                               0                               3.1                              1.52                             10.2                             1.54                             2.87
195.49 1080                     6.94                         7455                      30                            0                               0                               8.6                              1.54                             5.5                              1.5                              2.87
196.1  1080                     6.28                         7885                      30                            0                               0                               8.6                              1.52                             5.5                              1.48                             2.87
196.68 1040                     7.03                         8295                      30                            0                               0                               3.1                              1.5                              10.2                             1.48                             2.87
197.27 1040                     6.94                         8715                      30                            0                               0                               8.6                              1.54                             5.5                              1.48                             2.87
197.84 1040                     7.03                         9125                      30                            0                               0                               8.6                              1.52                             5.5                              1.5                              2.87
198.42 1080                     63                           10115                     30                            4.5                             4.5                             0                                1.16                             0                                1.16                             4.51
199.01 2400                     88                           15121                     30                            9                               6                               0                                1                                0                                0.98                             14.35
199.58 3560                     138.75                       23803                     30                            9                               6                               -7.8                             1                                -5.5                             1.08                             17.63
200.18 3960                     160.94                       33233                     330                           9                               5.3                             -7                               1.1                              -4.7                             1.04                             16.4
200.78 4360                     170.44                       43956                     330                           12                              11.3                            0                                0.76                             0                                0.86                             16.4
201.37 4320                     32.72                        49958                     330                           0                               0                               0                                0.86                             0                                1                                5.74
201.95 2800                     16.58                        51128                     330                           0                               0                               0                                1.12                             0                                1.18                             2.46
202.54 2720                     15.31                        51995                     432                           0                               0                               -4.7                             1.56                             -7.8                             1.48                             2.46
203.11 2520                     14.31                        52749                     432                           0                               0                               -6.3                             1.54                             0                                1.54                             2.46
203.71 2320                     12.89                        53427                     432                           0                               0                               0                                1.52                             0                                1.62                             2.46
204.3  2120                     12.25                        54091                     432                           0                               0                               0                                2.9                              0                                2.86                             2.46
204.87 1960                     11.53                        54725                     50                            0                               0                               0                                3.94                             0                                3.2                              2.46
205.45 1840                     9.86                         55301                     50                            0                               0                               0                                4.04                             0                                3.48                             2.46
206.04 1760                     8.58                         55389                     50                            0                               0                               0                                4.26                             0                                3.92                             0
206.61 1680                     8.42                         55400                     50                            0                               0                               0                                3.92                             0                                3.96                             0
207.19 1680                     17.58                        56194                     26                            0                               0                               0                                1.68                             0                                1.88                             3.69
207.8  1680                     14.86                        57121                     26                            0                               0                               0                                1.48                             0                                1.54                             4.1
208.37 1640                     11.47                        57847                     26                            0                               0                               -4.7                             1.44                             3.1                              1.52                             3.28
208.95 1560                     10.44                        58479                     26                            0                               0                               0                                1.48                             -3.1                             1.46                             2.87
209.54 1200                     7.5                          58971                     52                            0                               0                               -6.3                             1.5                              1.6                              1.54                             2.87
210.11 1120                     5.22                         59356                     52                            0                               0                               -0.8                             1.6                              3.9                              1.6                              2.46
210.69 1200                     8.86                         59841                     52                            0                               0                               2.3                              1.46                             -1.6                             1.44                             3.28
211.3  1160                     8.89                         60330                     52                            0                               0                               -4.7                             1.42                             2.3                              1.5                              2.87
211.87 1160                     8.39                         60790                     32                            0                               0                               -3.9                             1.52                             3.9                              1.52                             2.87
212.45 1160                     8.19                         61240                     32                            0                               0                               1.6                              1.54                             -0.8                             1.48                             2.87
213.04 1160                     8                            61690                     32                            0                               0                               -3.1                             1.5                              3.9                              1.52                             2.87
213.61 1120                     7.17                         62148                     32                            0                               0                               -3.9                             1.5                              3.9                              1.48                             2.87
214.19 1120                     7.39                         62544                     32                            0                               0                               0.8                              1.5                              -1.6                             1.46                             2.87
214.8  1080                     6.94                         62922                     32                            0                               0                               -4.7                             1.48                             3.9                              1.5                              2.87
215.37 960                      8.08                         63301                     32                            0                               0                               0                                1.5                              -1.6                             1.44                             2.87
215.95 960                      6.64                         63672                     32                            0                               0                               -1.6                             1.46                             -3.9                             1.4                              2.87
216.54 960                      7.67                         64078                     32                            0                               0                               -5.5                             1.5                              1.6                              1.5                              2.87
217.11 840                      6.67                         64444                     28                            0                               0                               -1.6                             1.5                              -4.7                             1.42                             2.87
217.69 720                      9.06                         64789                     28                            0                               0                               -1.6                             1.5                              -4.7                             1.48                             3.28
218.28 720                      5.81                         65144                     28                            0                               0                               -6.3                             1.56                             0.8                              1.5                              3.28
218.85 680                      6.44                         65463                     28                            0                               0                               0                                1.58                             -3.9                             1.52                             3.28
219.45 680                      5.78                         266                       24                            0                               0                               -3.9                             1.58                             1.6                              1.54                             3.69
220.04 680                      5.83                         614                       24                            9                               8.3                             0.8                              1.58                             0                                1.54                             3.28
220.6  1120                     21.92                        1630                      24                            6                               5.3                             0                                1.48                             0                                1.48                             8.61
221.18 1480                     25.89                        3213                      24                            6                               5.3                             -3.1                             1.52                             0.8                              1.48                             7.38
221.78 1480                     27                           4747                      68                            6                               5.3                             -3.1                             1.44                             1.6                              1.58                             6.97
222.34 1560                     28.14                        6450                      68                            6                               5.3                             1.6                              1.52                             -2.3                             1.5                              7.38
222.92 1600                     27.89                        8118                      68                            6                               5.3                             -3.1                             1.56                             1.6                              1.44                             7.38
223.53 1440                     9.39                         9273                      68                            0                               0                               -5.5                             1.48                             0                                1.5                              4.51
224.1  1160                     10.61                        9871                      102                           0                               0                               4.7                              1.66                             0                                1.6                              3.69
224.68 1120                     10.17                        10456                     102                           0                               0                               -1.6                             1.54                             3.1                              1.58                             3.69
225.27 1040                     9.03                         11002                     102                           0                               0                               2.3                              1.48                             -2.3                             1.46                             3.69
225.84 960                      7.69                         11493                     102                           0                               0                               0.8                              1.44                             -4.7                             1.44                             3.69
226.42 880                      7.17                         11913                     38                            0                               0                               -3.9                             1.52                             0                                1.5                              3.28
227.03 760                      6.61                         12285                     38                            0                               0                               1.6                              1.56                             -3.9                             1.54                             3.28
227.6  680                      6.25                         12609                     38                            0                               0                               2.3                              1.54                             -3.1                             1.56                             3.28
228.18 680                      6.19                         12937                     38                            0                               0                               -2.3                             1.56                             2.3                              1.54                             3.69
228.77 680                      6.69                         13301                     26                            0                               0                               3.1                              1.56                             -1.6                             1.54                             3.69
229.34 680                      6.53                         13693                     26                            0                               0                               -1.6                             1.54                             3.1                              1.54                             3.69
229.92 640                      7.5                          14069                     26                            0                               0                               -1.6                             1.54                             3.9                              1.52                             4.1
230.53 680                      6.56                         14481                     26                            0                               0                               3.1                              1.52                             -1.6                             1.5                              4.1
231.1  760                      7.92                         14899                     28                            0                               0                               -2.3                             1.52                             3.1                              1.52                             4.1
231.68 800                      6.78                         15339                     28                            0                               0                               -2.3                             1.54                             3.9                              1.5                              3.69
232.27 680                      36.97                        15844                     28                            0                               0                               0                                1.34                             0                                1.2                              3.69
232.84 1160                     23.39                        17012                     28                            0                               0                               -2.3                             1.52                             1.6                              1.52                             6.56
233.42 1200                     4.39                         18061                     56                            0                               0                               -3.1                             1.48                             1.6                              1.46                             6.15
234.03 760                      15.47                        18582                     56                            0                               0                               3.1                              1.58                             -3.1                             1.54                             4.1
234.6  760                      7.25                         19109                     56                            0                               0                               -1.6                             1.52                             2.3                              1.56                             4.51
235.18 720                      7.69                         19562                     56                            0                               0                               2.3                              1.52                             -2.3                             1.5                              4.1
235.77 720                      7.61                         19997                     56                            0                               0                               2.3                              1.52                             -3.1                             1.52                             4.1
236.34 720                      7.36                         20432                     34                            0                               0                               -2.3                             1.52                             3.1                              1.54                             4.1
236.92 680                      7.06                         20852                     34                            0                               0                               3.1                              1.56                             -1.6                             1.52                             4.1
237.53 800                      5.64                         21347                     34                            0                               0                               2.3                              1.48                             -0.8                             1.5                              4.51
238.1  720                      9.78                         21777                     34                            0                               0                               -3.1                             1.54                             3.9                              1.5                              4.1
238.68 560                      6.86                         22203                     32                            0                               0                               3.1                              1.54                             0                                1.52                             4.92
239.27 560                      7.94                         22646                     32                            0                               0                               0                                1.44                             1.6                              1.48                             5.74
239.84 920                      12.47                        23434                     32                            0                               0                               0                                1.4                              0                                1.32                             6.97
240.42 920                      10.58                        24208                     32                            0                               0                               1.6                              1.52                             -3.1                             1.46                             5.33
241.01 880                      14.56                        25014                     44                            0                               0                               -3.1                             1.48                             2.3                              1.46                             6.97
241.58 1200                     18.42                        26072                     44                            0                               0                               -1.6                             1.5                              3.1                              1.6                              6.15
242.18 1360                     19.03                        27222                     44                            0                               0                               0.8                              1.5                              -4.7                             1.42                             5.74
242.77 1480                     21.19                        28395                     44                            0                               0                               0                                1.56                             0                                1.5                              5.33
243.34 1800                     31.14                        30061                     82                            0                               0                               0                                1.44                             0                                1.42                             6.97
243.92 2040                     33.11                        31940                     82                            0                               0                               -0.8                             1.46                             -3.9                             1.5                              6.56
244.51 2280                     36.42                        33957                     82                            0                               0                               -3.9                             1.54                             0                                1.42                             6.15
245.08 2560                     40.83                        36264                     82                            0                               0                               0                                1.46                             -3.1                             1.56                             6.15
245.66 2840                     46.72                        38820                     152                           0                               0                               -0.8                             1.46                             -3.1                             1.44                             6.56
246.24 2280                     37.47                        41180                     152                           0                               0                               -4.7                             1.6                              0                                1.52                             6.56
246.85 1840                     12.75                        42519                     152                           0                               0                               3.9                              1.6                              -2.3                             1.58                             4.51
247.43 1760                     12.22                        43296                     152                           0                               0                               6.3                              1.58                             -0.8                             1.48                             3.28
248.02 1680                     11.47                        43975                     108                           0                               0                               0                                1.44                             3.1                              1.5                              2.87
248.59 1520                     10.83                        44579                     108                           0                               0                               3.9                              1.46                             -1.6                             1.48                             2.87
249.17 1280                     9.78                         45099                     108                           0                               0                               1.6                              1.48                             -2.3                             1.5                              2.87
249.74 1000                     8.5                          45592                     108                           0                               0                               -1.6                             1.58                             3.1                              1.56                             3.28
250.32 760                      6.75                         45982                     38                            0                               0                               2.3                              1.5                              -3.1                             1.48                             3.28
250.92 720                      6.11                         46403                     38                            0                               0                               -3.9                             1.44                             1.6                              1.5                              4.1
251.52 680                      6.53                         46777                     38                            0                               0                               -3.9                             1.5                              1.6                              1.5                              3.69
252.08 680                      6.33                         47128                     38                            0                               0                               1.6                              1.54                             -3.1                             1.52                             3.69
252.67 680                      7.94                         47510                     28                            0                               0                               -3.1                             1.56                             2.3                              1.54                             4.1
253.26 680                      7                            47917                     28                            0                               0                               -2.3                             1.58                             3.1                              1.54                             4.1
253.83 720                      7.72                         48390                     28                            0                               0                               1.6                              1.58                             0.8                              1.54                             4.51
254.41 1200                     18.64                        49394                     28                            0                               0                               0                                1.52                             0.8                              1.54                             6.56
254.99 1360                     18.69                        50580                     28                            0                               0                               -4.7                             1.44                             1.6                              1.5                              5.74
255.57 1440                     19.72                        51735                     56                            0                               0                               1.6                              1.58                             -3.9                             1.44                             5.33
256.15 1560                     20.33                        52898                     56                            0                               0                               -3.9                             1.52                             1.6                              1.5                              5.33
256.76 1720                     20.58                        54127                     56                            0                               0                               0.8                              1.46                             -3.9                             1.56                             4.92
257.33 1960                     29.64                        55615                     56                            0                               0                               0                                1.38                             0                                1.38                             5.74
257.91 2640                     94.89                        59743                     94                            9                               6                               0                                1.42                             0                                1.46                             11.89
258.49 3760                     157.03                       2292                      94                            9                               5.3                             -5.5                             1.3                              -4.7                             1.5                              15.99
259.08 3560                     143.28                       12361                     94                            9                               5.3                             -11.7                            0.72                             -10.9                            0.62                             19.27
259.66 3240                     123.69                       19784                     94                            9                               7.5                             -6.3                             1.12                             -4.7                             1.22                             14.76
260.24 3640                     142.17                       29024                     568                           12                              7.5                             -7.8                             1.08                             -5.5                             1.1                              17.22
260.82 4040                     152.47                       38607                     568                           12                              9.8                             -7                               1.16                             -5.5                             1.18                             15.99
261.42 4400                     172.33                       49288                     568                           12                              12                              -7                               1.12                             -4.7                             1.16                             15.99
262.06 4800                     181.75                       60781                     568                           11.3                            12                              -7.8                             1.24                             -5.5                             1.2                              15.58
262.69 5120                     201.28                       8264                      774                           11.3                            12                              -8.6                             1                                -5.5                             0.92                             15.58
263.33 4600                     27.97                        16470                     774                           0                               0                               0                                1.12                             0                                1.08                             8.2
263.92 3240                     17.89                        17700                     774                           0                               0                               0                                1.14                             0                                1.16                             2.46
264.51 2920                     16.31                        18687                     774                           0                               0                               -10.2                            1.5                              -6.3                             1.46                             2.46
265.08 2640                     15.31                        19469                     336                           0                               0                               -8.6                             1.5                              -2.3                             1.56                             2.46
265.68 2400                     12.69                        20171                     336                           0                               0                               -0.8                             1.6                              -6.3                             1.56                             2.46
266.27 2200                     13                           20855                     336                           0                               0                               0                                2.92                             0                                2.92                             2.46
266.84 2040                     11.36                        21495                     336                           0                               0                               0                                3.38                             0                                3.82                             2.46
267.42 1960                     10.11                        22104                     50                            0                               0                               0                                3.48                             0                                4.16                             2.46
268.01 1960                     23.61                        22771                     50                            0                               0                               3.9                              1.82                             18                               2.18                             2.46
268.58 1960                     29.33                        24135                     50                            8.3                             9                               -3.1                             1.16                             -5.5                             1.04                             5.74
269.19 1960                     29.03                        25731                     50                            8.3                             9                               -3.1                             1.54                             -7.8                             1.4                              5.33
269.78 1960                     29.03                        27292                     88                            8.3                             9                               -8.6                             1.5                              -3.1                             1.48                             5.33
270.34 2000                     27.31                        28817                     88                            8.3                             9                               -3.9                             1.46                             -7                               1.56                             5.33
270.92 2000                     15.17                        29970                     88                            0                               0                               0.8                              1.66                             -4.7                             1.56                             3.69
271.5  1960                     14.17                        30767                     88                            0                               0                               -3.1                             1.48                             1.6                              1.56                             2.87
272.08 2000                     26.17                        32023                     86                            5.3                             6                               -3.1                             1.34                             -6.3                             1.4                              4.92
272.68 1960                     24.86                        33400                     86                            5.3                             6                               -7                               1.56                             -1.6                             1.44                             4.92
273.27 2000                     24.25                        34728                     86                            5.3                             6                               -7                               1.42                             -1.6                             1.54                             4.51
273.84 2000                     24.33                        36080                     86                            5.3                             6                               -1.6                             1.48                             -5.5                             1.5                              4.51
274.42 2000                     23.06                        37393                     98                            5.3                             6                               -5.5                             1.56                             -0.8                             1.46                             4.51
275    2000                     22.36                        38661                     98                            5.3                             6                               -6.3                             1.4                              0                                1.54                             4.51
275.58 2000                     13.44                        39664                     98                            0                               0                               1.6                              1.58                             -3.9                             1.46                             3.28
276.16 1960                     17.92                        40438                     98                            0                               0                               -2.3                             1.56                             2.3                              1.5                              2.87
276.77 1960                     24.08                        41648                     98                            1.5                             2.3                             -7                               1.38                             -1.6                             1.46                             4.51
277.35 1960                     12.36                        42790                     78                            0                               0                               -0.8                             1.58                             -6.3                             1.46                             4.1
277.93 1920                     12.39                        43528                     78                            0                               0                               -3.9                             1.54                             0.8                              1.56                             2.87
278.52 1880                     17.56                        44385                     78                            0                               0                               1.6                              1.46                             -3.1                             1.54                             3.28
279.1  1880                     12.89                        45432                     78                            0                               0                               0                                1.54                             -6.3                             1.4                              3.69
279.68 1840                     12.22                        46179                     68                            0                               0                               -3.1                             1.5                              0                                1.54                             2.87
280.27 1840                     14.42                        46942                     68                            0                               0                               6.3                              1.58                             -1.6                             1.56                             3.28
280.86 1840                     16.44                        47841                     68                            0                               0                               7.8                              1.56                             -0.8                             1.48                             3.69
281.44 1840                     17.61                        48804                     68                            0                               0                               1.6                              1.42                             3.9                              1.48                             3.69
282.03 1840                     23.08                        50109                     62                            0                               0                               2.3                              1.42                             -3.9                             1.5                              4.92
282.6  1840                     24.94                        51480                     62                            0                               0                               3.1                              1.56                             -3.9                             1.46                             5.33
283.18 1880                     29.61                        53094                     62                            0                               0                               -3.1                             1.44                             0.8                              1.54                             6.15
283.76 1880                     29.31                        54807                     62                            0                               0                               0.8                              1.44                             -3.9                             1.54                             6.15
284.34 1960                     34.14                        56625                     112                           0                               0                               -3.9                             1.56                             0                                1.46                             6.56
284.94 2000                     45.28                        59008                     112                           0                               0                               -4.7                             1.32                             -0.8                             1.48                             8.2
285.53 2040                     13.17                        60555                     112                           0                               0                               6.3                              1.68                             0.8                              1.62                             4.51
286.1  2000                     12.36                        61352                     112                           0                               0                               3.1                              1.56                             7.8                              1.56                             2.87
286.68 1960                     21.28                        62124                     112                           0                               0                               2.3                              1.38                             6.3                              1.44                             2.87
287.26 2000                     30.39                        63628                     112                           0                               0                               1.6                              1.48                             -3.9                             1.44                             4.92
287.84 2040                     37                           12                        112                           0                               0                               -3.9                             1.52                             0                                1.44                             6.15
288.42 2080                     35.22                        2096                      112                           0                               0                               -0.8                             1.44                             -3.1                             1.56                             6.97
289.03 2120                     29.03                        3905                      124                           0                               0                               0                                1.56                             -3.1                             1.46                             5.74
289.6  2160                     24.97                        5508                      124                           0                               0                               -3.1                             1.58                             1.6                              1.48                             4.92
290.18 2160                     25.39                        6975                      124                           0                               0                               0.8                              1.44                             -3.1                             1.54                             4.51
290.76 2200                     23.64                        8353                      124                           0                               0                               2.3                              1.56                             -2.3                             1.46                             4.51
291.34 2200                     14.11                        9446                      106                           0                               0                               -0.8                             1.56                             3.9                              1.58                             3.28
291.92 2160                     11.86                        10208                     106                           0                               0                               5.5                              1.52                             0                                1.5                              2.46
292.5  2120                     12.33                        10905                     106                           0                               0                               5.5                              1.54                             0                                1.5                              2.46
293.11 2080                     12.03                        11585                     106                           0                               0                               1.6                              1.48                             6.3                              1.56                             2.46
293.69 1880                     9.89                         12210                     52                            0                               0                               0                                1.84                             0                                1.94                             2.46
294.28 1720                     8.5                          12724                     52                            0                               0                               0                                3.1                              0                                3.06                             2.46
294.85 1560                     7.83                         13162                     52                            0                               0                               0                                3.34                             0                                3.52                             2.46
295.43 880                      11.94                        13568                     52                            0                               0                               0                                2.28                             0                                2.46                             2.87
296.01 1120                     15.39                        14348                     38                            0                               0                               0                                1.56                             0                                1.64                             4.1
296.59 1680                     54.94                        16779                     38                            4.5                             4.5                             0                                1.42                             0                                1.44                             12.3
297.19 1280                     40.28                        19195                     38                            4.5                             4.5                             1.6                              1.54                             -1.6                             1.5                              12.71
297.78 1360                     43.5                         21694                     38                            3.8                             3.8                             -2.3                             1.56                             0.8                              1.46                             12.3
298.35 1400                     42.44                        24258                     38                            3.8                             3.8                             -2.3                             1.46                             0.8                              1.58                             12.3
298.93 1480                     36.89                        26552                     180                           3.8                             3.8                             0.8                              1.56                             -3.1                             1.48                             10.25
299.51 1560                     34.89                        28629                     180                           3.8                             3.8                             0                                1.38                             0                                1.46                             9.02
300.09 1520                     11.28                        29561                     180                           0                               0                               1.6                              1.6                              2.3                              1.62                             3.69
300.68 1520                     10.75                        30219                     180                           0                               0                               7.8                              1.58                             3.9                              1.6                              3.28
301.28 1520                     17.67                        31058                     104                           0                               0                               0.8                              1.42                             7.8                              1.46                             4.1
301.84 1520                     25.19                        32194                     104                           0.8                             0.8                             1.6                              1.36                             -2.3                             1.4                              4.92
302.42 2080                     26.47                        33668                     104                           0                               0                               1.6                              1.56                             -3.9                             1.42                             4.92
303    2120                     25.78                        35220                     104                           0                               0                               -3.1                             1.5                              0.8                              1.48                             4.92
303.58 3160                     39.28                        37189                     94                            0                               0                               0                                1.42                             -2.3                             1.54                             4.92
304.18 3240                     65.19                        40380                     94                            0                               0                               0                                1.4                              0                                1.34                             7.38
304.77 3400                     83.39                        44940                     94                            3                               0                               -4.7                             1.5                              -0.8                             1.44                             9.43
305.34 3600                     90.72                        49953                     94                            3                               0                               -1.6                             1.3                              -2.3                             1.38                             9.84
305.93 3760                     33.5                         53566                     290                           0                               0                               -4.7                             1.6                              1.6                              1.5                              5.33
306.52 3720                     21.28                        55021                     290                           0                               0                               -1.6                             1.5                              4.7                              1.58                             2.87
307.09 3600                     19.83                        56186                     290                           0                               0                               3.9                              1.58                             2.3                              1.58                             2.46
307.69 3560                     29.86                        57754                     290                           0                               0                               -2.3                             1.5                              3.9                              1.4                              3.69
308.28 3520                     32.78                        59584                     118                           0                               0                               -4.7                             1.42                             2.3                              1.54                             4.1
308.85 3480                     34.61                        61461                     118                           0                               0                               -0.8                             1.44                             -3.1                             1.46                             4.1
309.43 3480                     35.17                        63444                     118                           0                               0                               -4.7                             1.56                             0.8                              1.46                             4.1
310.01 3440                     23.81                        65230                     118                           0                               0                               -0.8                             1.48                             -3.9                             1.56                             4.1
310.59 3360                     18.78                        866                       130                           0                               0                               1.6                              1.58                             -2.3                             1.5                              2.46
311.18 3240                     17.86                        1898                      130                           0                               0                               -1.6                             1.54                             3.1                              1.46                             2.46
311.79 3120                     17.56                        2907                      130                           0                               0                               3.1                              1.44                             -1.6                             1.56                             2.46
312.36 3000                     17.17                        3868                      130                           0                               0                               0                                2.4                              0                                2.02                             2.46
312.94 2840                     16.42                        4787                      72                            0                               0                               0                                3.56                             0                                3.08                             2.46
313.53 2640                     15.17                        5622                      72                            0                               0                               0                                4.1                              0                                3.24                             2.46
314.1  2360                     13.58                        6040                      72                            0                               0                               0                                4.1                              0                                4                                0
314.69 2080                     12.56                        6040                      72                            0                               0                               0                                4.28                             0                                4.06                             0
315.28 1800                     9.44                         6040                      26                            0                               0                               0                                4.18                             0                                4.16                             0
315.85 1520                     11.17                        6470                      26                            0                               0                               0                                2.36                             0                                2.7                              2.87
316.43 1360                     11.22                        7041                      26                            0                               0                               0                                1.84                             0                                1.98                             2.87
317.01 1240                     10.03                        7591                      26                            0                               0                               0                                1.66                             0                                1.7                              3.28
317.59 1160                     18.44                        8238                      38                            0                               0                               3.9                              1.6                              3.9                              1.58                             3.69
318.17 1360                     22.06                        9551                      38                            0                               0                               0                                1.42                             0                                1.4                              6.97
318.76 1760                     34.06                        11410                     38                            0                               0                               0                                1.42                             0                                1.4                              7.38
319.36 1960                     48.03                        13804                     38                            0                               0                               0                                1.42                             0                                1.4                              10.25
319.94 2200                     54.31                        16838                     38                            0                               0                               0                                1.4                              0                                1.44                             9.84
320.53 2520                     95.67                        21360                     156                           3                               6                               0                                1.36                             0                                1.38                             13.12
321.1  2760                     105.22                       27155                     156                           9                               6                               -2.3                             1.1                              -3.1                             1.12                             14.35
321.68 3040                     122.14                       34147                     156                           9                               6                               -7.8                             1.24                             -7                               1.24                             15.17
322.26 3480                     146.92                       42161                     156                           12                              9                               -5.5                             0.9                              -3.9                             1.02                             15.99
322.86 3840                     120.11                       51192                     476                           12                              9                               0                                0.38                             0                                0.58                             16.81
323.44 3840                     26.78                        53962                     476                           0                               0                               0                                0.9                              0                                1.06                             4.1
324.03 3760                     20.94                        55289                     476                           0                               0                               -3.9                             1.2                              -4.7                             1.34                             2.87
324.6  3640                     21.03                        56422                     476                           0                               0                               -8.6                             1.5                              -1.6                             1.46                             2.46
325.18 3520                     20                           57565                     232                           0                               0                               -3.9                             1.44                             -4.7                             1.52                             2.46
325.76 3400                     24.39                        58699                     232                           0                               0                               -3.9                             1.4                              5.5                              1.58                             2.46
326.34 3400                     27.14                        60261                     232                           0                               0                               -8.6                             1.4                              -0.8                             1.46                             3.28
326.94 3360                     25.61                        61689                     232                           0                               0                               -3.9                             1.44                             -6.3                             1.48                             3.28
327.53 3280                     18.53                        62821                     96                            0                               0                               -7.8                             1.56                             -0.8                             1.48                             2.46
328.1  3160                     18                           63794                     96                            0                               0                               -4.7                             1.5                              0.8                              1.6                              2.46
328.68 3120                     17.67                        64967                     96                            0                               0                               -4.7                             1.5                              -7.8                             1.42                             2.87
329.26 2920                     17                           359                       96                            0                               0                               -9.4                             1.54                             -2.3                             1.48                             2.46
329.83 2480                     14.56                        1088                      72                            0                               0                               0                                2.08                             0                                2.1                              2.46
330.43 1640                     8.42                         1088                      72                            0                               0                               0                                3.66                             0                                3.46                             0
331.03 1240                     6.03                         1110                      72                            0                               7.5                             0                                3.26                             0                                3.34                             0
331.59 1400                     13.08                        1913                      72                            0                               0                               0                                1.68                             0                                1.76                             4.1
332.17 1440                     42.58                        3101                      30                            3                               0                               0                                1.26                             0                                1.32                             6.15
332.75 1560                     56.86                        5498                      30                            3                               0                               0                                1.22                             0                                1.28                             10.66
333.33 1480                     48.28                        8312                      30                            3                               3                               0                                1.26                             0                                1.3                              13.12
333.94 1600                     50.5                         11287                     30                            3                               3                               -5.5                             1.54                             -7.8                             1.46                             12.3
334.77 1720                     57.94                        15570                     194                           3                               3                               0                                1.36                             0                                1.32                             12.3
335.36 1640                     7.14                         17061                     194                           0                               0                               0                                1.26                             0                                1.3                              4.51
335.93 1320                     10.75                        17602                     194                           0                               0                               0                                1.48                             0                                1.52                             3.28
336.51 1280                     10.11                        18163                     194                           0                               0                               -2.3                             1.52                             2.3                              1.52                             3.28
337.1  1280                     5.72                         18688                     88                            0                               0                               -2.3                             1.46                             2.3                              1.52                             2.87
337.67 1120                     6.08                         19050                     88                            0                               0                               2.3                              1.56                             -1.6                             1.6                              2.46
338.25 1240                     9.89                         19567                     88                            0                               0                               -4.7                             1.36                             3.1                              1.48                             3.28
338.86 1200                     9.53                         20084                     88                            0                               0                               -6.3                             1.48                             0.8                              1.46                             3.28
339.43 1160                     8.56                         20558                     34                            0                               0                               0.8                              1.56                             -2.3                             1.52                             2.87
340.01 1120                     7.86                         20998                     34                            0                               0                               -2.3                             1.56                             3.1                              1.58                             2.87
340.6  1080                     6.92                         21438                     34                            0                               0                               4.7                              1.62                             0.8                              1.58                             2.87
341.17 1080                     7.39                         21878                     34                            0                               0                               5.5                              1.58                             0.8                              1.58                             2.87
341.75 1040                     6.78                         22298                     32                            0                               0                               0                                1.54                             6.3                              1.56                             2.87
342.36 1040                     6.31                         22674                     32                            0                               0                               4.7                              1.56                             0.8                              1.52                             2.87
342.93 1000                     6.83                         23052                     32                            0                               0                               4.7                              1.56                             0.8                              1.54                             2.87
343.51 1160                     13.25                        23703                     32                            0                               0                               0                                1.5                              6.3                              1.56                             4.51
344.1  1160                     14                           24506                     38                            0                               0                               3.9                              1.58                             -1.6                             1.54                             4.51
344.67 1000                     7                            25175                     38                            0                               0                               -1.6                             1.54                             3.1                              1.56                             4.1
345.25 1000                     7.39                         25647                     38                            0                               0                               -3.1                             1.48                             2.3                              1.5                              3.28
345.86 1000                     7.64                         26087                     38                            0                               0                               2.3                              1.54                             -2.3                             1.52                             3.28
346.43 1000                     6.61                         26483                     36                            0                               0                               -2.3                             1.5                              3.1                              1.54                             2.87
347.02 1000                     6.39                         26877                     36                            0                               0                               -1.6                             1.52                             3.1                              1.52                             2.87
347.61 960                      6.58                         27231                     36                            0                               0                               3.1                              1.54                             -2.3                             1.5                              2.87
348.18 1080                     6.94                         27600                     36                            0                               0                               -1.6                             1.56                             3.1                              1.58                             2.87
348.76 1120                     7.86                         28026                     28                            0                               0                               -0.8                             1.56                             3.9                              1.54                             2.87
349.34 1040                     7.44                         28456                     28                            0                               0                               1.6                              1.48                             -3.1                             1.44                             2.87
349.92 1120                     12.06                        28911                     28                            0                               0                               -1.6                             1.6                              2.3                              1.56                             2.87
350.52 1520                     30.03                        30296                     28                            0                               0                               0                                1.46                             0                                1.5                              7.38
351.11 1520                     40.31                        32408                     28                            0                               0                               0                                1.42                             0                                1.44                             9.02
351.69 1520                     56.44                        35268                     82                            6                               0.8                             0                                1.4                              0                                1.4                              12.3
352.27 1680                     56.67                        38497                     82                            6                               4.5                             -0.8                             1.44                             -4.7                             1.5                              13.12
352.86 1760                     49.17                        41681                     82                            6                               4.5                             0                                1.44                             0                                1.36                             12.3
353.43 1800                     7.56                         43336                     82                            0                               0                               0                                1.46                             0                                1.4                              4.92
354.01 1320                     10.42                        43883                     192                           0                               0                               2.3                              1.58                             0.8                              1.56                             2.87
354.59 1320                     9.42                         44393                     192                           0                               0                               7.8                              1.6                              0                                1.58                             2.87
355.19 1280                     7.61                         44891                     192                           0                               0                               2.3                              1.5                              6.3                              1.56                             2.87
355.77 1120                     5.69                         45274                     192                           0                               0                               2.3                              1.56                             -1.6                             1.56                             2.46
356.36 1120                     8.58                         45703                     34                            0                               0                               -0.8                             1.54                             5.5                              1.56                             2.87
356.93 1040                     7.92                         46153                     34                            0                               0                               -1.6                             1.52                             4.7                              1.52                             2.87
357.51 1000                     7.89                         46604                     34                            0                               0                               3.9                              1.54                             -0.8                             1.5                              3.28
358.09 960                      7.92                         47022                     34                            0                               0                               -0.8                             1.52                             3.9                              1.52                             3.28
358.69 1360                     34.22                        47953                     32                            3                               1.5                             0.8                              1.48                             0                                1.46                             4.92
359.27 1480                     54.53                        49979                     32                            4.5                             4.5                             0                                1.48                             0                                1.48                             11.48
359.86 1320                     43.08                        52495                     32                            3.8                             4.5                             0                                1.52                             0                                1.5                              12.71
360.42 1440                     45.22                        55145                     32                            6.8                             3.8                             -3.1                             1.46                             0.8                              1.5                              12.71
361    1560                     52.5                         57970                     168                           6.8                             3.8                             0.8                              1.52                             -3.9                             1.46                             12.71
361.58 1640                     54.28                        61072                     168                           6.8                             3.8                             -3.1                             1.54                             -0.8                             1.48                             12.71
362.16 1760                     61.61                        64332                     168                           6.8                             3.8                             0                                1.46                             -3.9                             1.5                              12.71
362.76 1800                     8.36                         1371                      168                           6                               3.8                             0                                1.26                             0                                1.22                             10.66
363.35 1680                     11.67                        2061                      190                           0                               0                               1.6                              1.58                             0                                1.52                             2.87
363.92 1240                     10.25                        2586                      190                           0                               0                               5.5                              1.6                              0                                1.58                             2.87
364.5  1200                     9.19                         3111                      190                           0                               0                               7.8                              1.58                             2.3                              1.58                             3.28
365.08 1160                     5.11                         3564                      190                           0                               0                               -2.3                             1.52                             2.3                              1.56                             2.87
365.66 1120                     8.33                         4003                      36                            0                               0                               3.1                              1.56                             -0.8                             1.5                              2.87
366.26 1040                     7.94                         4454                      36                            0                               0                               -2.3                             1.5                              3.1                              1.5                              3.28
366.85 960                      8.08                         4883                      36                            0                               0                               -2.3                             1.5                              2.3                              1.48                             3.28
367.42 1080                     8.19                         5323                      36                            0                               0                               3.9                              1.58                             -1.6                             1.56                             3.28
368    1000                     7.72                         5785                      32                            0                               0                               0                                1.54                             4.7                              1.56                             3.28
368.6  920                      6.89                         6205                      32                            0                               0                               -1.6                             1.52                             3.9                              1.48                             3.28
369.18 800                      6.28                         6557                      32                            0                               0                               3.1                              1.52                             -2.3                             1.5                              3.28
369.76 680                      8.11                         6921                      32                            0                               0                               -1.6                             1.52                             3.1                              1.52                             3.69
370.35 680                      5.5                          7274                      26                            0                               0                               -2.3                             1.52                             3.1                              1.5                              3.69
370.94 640                      7.25                         7619                      26                            0                               0                               2.3                              1.5                              -2.3                             1.5                              3.69
371.52 680                      6.25                         8006                      26                            0                               0                               -3.1                             1.48                             1.6                              1.5                              4.1
372.11 640                      8.78                         8433                      26                            3                               3                               0                                1.46                             0                                1.46                             5.74
372.68 720                      8.39                         8914                      26                            3                               3                               0.8                              1.48                             -4.7                             1.46                             4.51
373.26 680                      7.28                         9345                      30                            0                               0                               -3.9                             1.5                              0                                1.48                             4.1
373.85 640                      6.83                         9737                      30                            0                               0                               0.8                              1.5                              -5.5                             1.48                             4.1
374.69 600                      6.58                         10262                     30                            0                               0                               -0.8                             1.46                             -6.3                             1.46                             4.1
375.27 600                      6.25                         10633                     28                            0                               0                               -7                               1.42                             -2.3                             1.48                             4.1
375.86 600                      5.78                         10955                     28                            0                               0                               -8.6                             1.46                             -3.1                             1.46                             4.1
376.43 600                      5.86                         11274                     28                            0                               0                               -3.9                             1.48                             -8.6                             1.46                             3.69
377.01 560                      5.81                         11573                     28                            0                               0                               -9.4                             1.48                             -4.7                             1.5                              3.69
377.6  560                      5.83                         11872                     22                            0                               0                               -9.4                             1.52                             -3.9                             1.5                              3.69
378.17 600                      5.53                         12184                     22                            0                               0                               -3.9                             1.52                             -9.4                             1.5                              3.69
378.75 560                      5.56                         12483                     22                            0                               0                               -8.6                             1.54                             -4.7                             1.54                             3.69
379.34 560                      5.64                         12782                     22                            0                               0                               -8.6                             1.54                             -3.9                             1.52                             3.69
379.93 560                      5.56                         13068                     22                            0                               0                               -3.9                             1.54                             -9.4                             1.54                             3.69
380.51 560                      5.61                         13367                     20                            0                               0                               -8.6                             1.54                             -3.9                             1.54                             3.69
381.1  560                      5.58                         13666                     20                            0                               0                               -3.9                             1.54                             -8.6                             1.54                             3.69
381.67 560                      5.5                          13952                     20                            0                               0                               -3.9                             1.52                             -7.8                             1.56                             3.69
382.25 560                      5.69                         14251                     20                            0                               0                               -8.6                             1.54                             -3.1                             1.54                             3.69
382.84 560                      5.5                          14563                     20                            0                               0                               -3.1                             1.56                             -7.8                             1.54                             3.69
383.41 560                      5.56                         14862                     20                            0                               0                               -3.1                             1.54                             -7.8                             1.54                             3.69
384.01 560                      5.5                          15148                     20                            0                               0                               -7.8                             1.56                             -2.3                             1.54                             3.69
384.6  560                      5.5                          15447                     20                            0                               0                               -2.3                             1.54                             -7                               1.54                             3.69
385.17 560                      5.44                         15746                     20                            0                               0                               -2.3                             1.54                             -7                               1.54                             3.69
385.75 560                      5.58                         16032                     20                            0                               0                               -7                               1.56                             -2.3                             1.54                             3.69
386.34 560                      5.53                         16344                     20                            0                               0                               -2.3                             1.54                             -7                               1.54                             3.69
386.91 560                      5.58                         16630                     20                            0                               0                               -7                               1.52                             -1.6                             1.54                             3.69
387.51 560                      5.44                         16929                     20                            0                               0                               -7                               1.54                             -1.6                             1.52                             3.69
Old 5th October 2016, 09:59 AM
Hello Matthew , using my mass air flow calculator im getting
640 rpm 6.7 g/s
2000 rpm 20.05 g/s
So we are loosing air.... or the reporting of air mass is off ( air mass meter ).... or air cannot get into engine (blocked exhaust route )
Does the car pull well if you put your foot down .....with blocked cats the more you boot it the more it will die a death from lack of flow
For it to affect idle readings the cats or exhaust would have to be pretty blocked which would kill mid and top end .
You say you have had a genuine air mass ......is this genuine audi part or a genuine bosch one from a motor factors or Euro car blaggers or somewhere ??
loads of Chinese copy supposedley gen. bosch air masses out there ........seen this a few times now ......under performing air masses affecting fueling ........seen over performing ones as well .......black smoke r us .
Try this i want to see if the lamdas are reading rich .............
clear all adaptations first .......go into short term fuel trims for both banks hold rpm at say 2000 if trims start going to plus values ( ecm adding fuel ) slowly clamp off fuel return line from injector rail .........making it artificially rich ........do the trims start going the other way minus readings ( ecm taking away fuel )
I just want to see that the ecm can respond to a rich .
If there is no fuel return rail ( return done internally in tank ) just squirt brake cleaner or easy start up the inlet ...... i just want to know lamdas and ecm can see it going rich .
At this stage now i would be smoke testing inlet manifold and doing a vac test to see manifold integrity ...... i dont know if you have the gear to do this ??
The air mass reading being down is were i want to be going , all exit points off inlet manifold need to be ruled out ........... so ..... breather pipes to pcv , brake servo pipe things like that , have you had a spray around inlet maniflod with brake cleaner to see if it draws it in anywhere.
If all this checks out as good .......next step injectors out for spray and quantity testing .
Also did you try driving with air mass un plugged to see what happens with fuel trims .
If you let me know where abouts you are in the country i could see if any of the pro diagnostic garages that are on the closed diag forums that im on could help you with carrying out a smoke test and manifold tests and so on .
Say £50 for an hours diag maybe well spent especially with someone who knows what there doing ........better than guess at this that and the other .
Im not preaching here by the way ........ near enough every week i see car coming in with egrs , injectors , map sensors , air masses , coil packs you name it 100s and 100s of pounds in parts ( guess a part squad ) and yes some garages are just as bad ...... test not guess ........test rule out ...move on .
Let us know how you get on
Lee
Old 5th October 2016, 10:51 AM
Air flow is not as simple a s fixed value at certain rpm. There will be massive difference at 2000rpm depending how much throttle is open. There are some readings in the log around 2000rpm with 45g/ms and the highest reading is 201.28g/s at 5120 rpm so the values seem plausible.
Lambda correction seams to be all over the place from -11.7% to +18%
I have made a chart in excel, it does not look that correction depends on either rpm or airlow so really don't know whats going on.
Old 5th October 2016, 12:54 PM
Thanks to both of you for spending some time looking at the logs.
The MAF sensor was my first thought when I first bought the car 12 months ago. There was no MAF specific codes but I replaced it as a precaution as it looked original. The first one I fitted was a new genuine Audi part (although bought on eBay from someone who never fitted it - it was still boxed and looked genuine). This didn't make any difference. A few months ago I purchased a new Bosch MAF in case the previous one I purchased was dodgy (this time brand new from Amazon - not a third party seller. All seems genuine and I verified the serial number on the Bosch website). Still made no difference unfortunately so I think I can rule out the MAF sensor itself.
I'd say the car seems to pull fine up to the limiter. I also have a 300BHP Mondeo and the A8 certainly feels a bit more powerful, despite the quattro and automatic gearbox power losses.
If anything, I'd say it struggles at low RPM (<2000). If driving at a steady 30mph and go to accelerate, the engine labours a bit for a second before dropping a gear. This is my first automatic car so I'm not sure if this is to be expected - I assume in "D" mode it tries to keep the car in the highest gear possible. This isn't as bad when driving in "S" mode as the revs are held higher.
I'm pretty sure there are no leaks from the intake manifold. When I had it off last week, I went over every vacuum hose and PCV breather and they all seem good. Throttle body gasket and intake manifold gaskets were replaced. Only area I've not checked is the brake booster - I believe the brake booster pressure can be checked with VCDS so I'll look into that.
I've also checked for leaks with brake cleaner and propane around the manifold and injector o-rings but none found. The car has done 150k miles and when I recently replaced the fuel filter it was pretty clogged.
I noticed on my logs there was some timing retardation (up to 12) at high RPM. Is this normal? This is not an area I'm too familiar with.
I'll try the tests you mentioned tonight (unplug MAF and also simulate rich condition).
I'm in the Bolton area so not too far away.
ainarssems: Thanks for the chart. You're right in saying there is no obvious pattern to this behaviour and also no fault codes other than "too lean". The only symptom seems to be the MPG!
Thanks
- 2005 Audi A8 D3 4.2L Petrol
- 2008 Ford Mondeo 2.5T
- 2000 Ford Focus 1.6
Old 5th October 2016, 02:31 PM
Just added a quick video showing the MPG drop from a cold start.
It shows the MPG start off at a steady 15mpg then immediately drops to 5mpg at around 20 seconds in.
(Airbag warning light is a faulty passenger airbag disable switch, screenwash is about to be topped up!)
Another thought - are intake temperatures worth logging?
Old 5th October 2016, 03:18 PM
My MPG counter does the same as yours in that video. Once driving mine starts to steady out and climb after a minute / few hundred meters. Have you recorded real fuel usage between fill up's?
Matt
Old 5th October 2016, 03:32 PM
Hi, does yours drop as low as 5? Mine always seems to start at 15 then drops to 5.
It does slowly climb back up over the next couple of miles but seems to go back up to around 13mpg over the last few days on a clear run.
I've never calculated the real consumption before but I put £20 of petrol in every 2 days, and drive 25 miles per day, so £20 gives me 50 miles. (tank is always close to empty when filling up)
At £1.09/litre, £20 = 4.1 gallons.
50/4.1 = 12.2mpg
So the real consumption does reflect the readings. It definitely seems too low - my Mondeo averages 24mpg on the same journey and that engine is notorious for low MPG (Volvo T5 engine).
Thanks
Old 5th October 2016, 03:45 PM
Yes, it starts at 15.0 and climbs to 15.9 then back to 15.0 then climbs again. It has dropped to single figure MPG then climbs. It's like the DIS computer is calculating values until it has enough data. On a 25 mile journey I do I usually see around 30mpg for that trip.
Matt
Old 5th October 2016, 06:38 PM
Have you measured actual fuel consumption, i.e. how many miles per tank?
DIS is not always a good indicator, especially real time. Easy to go from 100MPG to single figures as you go from coasting to WOT in my S4
